Outils recommandés dans ce démontage
Introduction
LED touch light Teardown
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Flashlight, utilisez notre manuel de réparation.
  1. The assembled light.
    • The assembled light.
  2. Twist the mounting plate clockwise, then lift to remove it.
    • Twist the mounting plate clockwise, then lift to remove it.
  3. Remove the three AAA batteries from their holders.
    • Remove the three AAA batteries from their holders.
  4. Loosen and remove the four Phillips screws.
    • Loosen and remove the four Phillips screws.
  5. Having removed the four Phillips screws in the previous step, separate the assembly as shown.
    • Having removed the four Phillips screws in the previous step, separate the assembly as shown.
  6. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  7. Remove the three springs.
    • Remove the three springs.
  8. Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
    • Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
  9. Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
    • Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
  10. Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
    • Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
  11. Lift and separate the power switch from the main assembly.
    • Lift and separate the power switch from the main assembly.
  12. Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
    • Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
  13. The separated lens, case and reflector elements.
    • The separated lens, case and reflector elements.
  14. The full assortment of separated parts.
    • The full assortment of separated parts.
Vimal
Membre depuis le 21/07/2013
219 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 23
Total : 2,348
