Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre LG Tribute Royal, utilisez notre manuel de réparation.
  1. LG Tribute Royal Teardown, Remove back panel: étape 1, image 1 de 3 LG Tribute Royal Teardown, Remove back panel: étape 1, image 2 de 3 LG Tribute Royal Teardown, Remove back panel: étape 1, image 3 de 3
    • Use a spudger to open the back panel and disconnect it from the phone.
  2. LG Tribute Royal Teardown, Unscrew all the screws: étape 2, image 1 de 2 LG Tribute Royal Teardown, Unscrew all the screws: étape 2, image 2 de 2
    • Unscrew all 16 screws holding the back panel cover on to the phone
  3. LG Tribute Royal Teardown, Remove back cover: étape 3, image 1 de 2 LG Tribute Royal Teardown, Remove back cover: étape 3, image 2 de 2
    • Apply adequate force to the back panel to remove it from the phone
  4. LG Tribute Royal Teardown, Remove battery: étape 4, image 1 de 3 LG Tribute Royal Teardown, Remove battery: étape 4, image 2 de 3 LG Tribute Royal Teardown, Remove battery: étape 4, image 3 de 3
    • Disconnect the ribbon cable that connects the battery to the motherboard. I suggest you heat up the battery first because of the glue and not do what i did. Use spudger to pry up the battery from the device.
  5. LG Tribute Royal Teardown, Remove back camera: étape 5, image 1 de 2 LG Tribute Royal Teardown, Remove back camera: étape 5, image 2 de 2
    • Disconnect the back camera from the motherboard by disconnecting the connector from the motherboard
  6. LG Tribute Royal Teardown, Remove front camera: étape 6, image 1 de 2 LG Tribute Royal Teardown, Remove front camera: étape 6, image 2 de 2
    • Disconnect the front camera from the phone by disconnecting the ribbon cable from the front camera attached to the motherboard.
  7. LG Tribute Royal Teardown, Disconnect display: étape 7, image 1 de 2 LG Tribute Royal Teardown, Disconnect display: étape 7, image 2 de 2
    • Disconnect the display ribbon cable from the motherboard.
  8. LG Tribute Royal Teardown, Remove motherboard: étape 8, image 1 de 2 LG Tribute Royal Teardown, Remove motherboard: étape 8, image 2 de 2
    • To remove the motherboard apply adequate pressure because there will be some resistance. Try to avoid as much thermal paste as you can.
  9. LG Tribute Royal Teardown, Remove sim card and holder: étape 9, image 1 de 2 LG Tribute Royal Teardown, Remove sim card and holder: étape 9, image 2 de 2
    • To remove sim card just push it out the side. The sim card will be in the holder.
  10. LG Tribute Royal Teardown, Remove Vibrator Motor: étape 10, image 1 de 2 LG Tribute Royal Teardown, Remove Vibrator Motor: étape 10, image 2 de 2
    • Disconnect the ribbon cable holding down the vibrator motor then remove it.
  11. LG Tribute Royal Teardown, Remove Speaker: étape 11, image 1 de 1
    • Remove the speaker at the top of the phone.
  12. LG Tribute Royal Teardown, Remove microphones: étape 12, image 1 de 2 LG Tribute Royal Teardown, Remove microphones: étape 12, image 2 de 2
    • Remove microphones
  13. LG Tribute Royal Teardown, Remove side buttons: étape 13, image 1 de 2 LG Tribute Royal Teardown, Remove side buttons: étape 13, image 2 de 2
    • Remove the side buttons by disconnecting the ribbon cables on each one.
  14. LG Tribute Royal Teardown, Reassemble the phone: étape 14, image 1 de 1
    • Follow the steps backwards in order to reassemble the phone.
    • Be sure to clean the sim card with compressed air or else it wont work
Rose Schneider
Membre depuis le 05/01/21
413 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 15
Total : 838
