Aller au contenu principal
Vidéo d'introduction
Introduction
How to completely disassemble your tablet.
__________Video tutorial:__________
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Lenovo Ideatab A1000, utilisez notre manuel de réparation.
  1. Unscrew the two Phillips screws under the memory card and the SIM card covers. Use a plastic tool and remove the back cover. Use a plastic tool and remove the back cover.
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Unscrew the 8x screws and remove the mother board cover. Disconnect the battery connector. Disconnect the battery connector.
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Volume Buttons, Power Button and Vibration motor Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector. Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Remove the lower speaker and the microphone. Unstuck the Power button, Volume buttons and Vibration motor from the middle frame. Unhook the LCD Display and the Touch screen flex cables.
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Remove the Logic board. Be careful, the mother board is sticked to the front outer case. Be careful, the mother board is sticked to the front outer case.
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. CPU - Mediatek, MT8317ATA Memory chip -  eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410 Power management chip - Mediatek MT6329BA
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
Membre depuis le 09/12/2013
178 525 Réputation
315 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
297 membres
982 tutoriels rédigés
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Réponse
Thanks for this guide!
Pooshon Banerjee - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 13,609
