Aller au contenu principal
Introduction
This guide will show the teardown of a Linksys WAG200G gateway.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Linksys WAG200G, utilisez notre manuel de réparation.
  1. Turn the router with the bottom facing upwards and locate the 4 feet. Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
    • Turn the router with the bottom facing upwards and locate the 4 feet.
    • Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
    • The front of the case can be disconnected from the backside now.
  2. The antenna cable is soldered to the board. It can be unsoldered or just cut. Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
    • The antenna cable is soldered to the board. It can be unsoldered or just cut.
    • Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
  3. The board can now be removed from the case easily.
    • The board can now be removed from the case easily.
    • 10/100 Base-T Dual Port Transformer: HN2064CG
    • CPU: TNETD7200ZDW
    • 10/100 Ethernet Switch : 88E6060-RCJ1
knipwim
Membre depuis le 01/09/2018
3 779 Réputation
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 1,038
