Aller au contenu principal
Outils recommandés dans ce démontage
Introduction
This is a step by step teardown of a Logitech webcam which is helpful if you are trying to build a stereo camera and remove the infrared filter or even simply adjust the focus.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Logitech 2-MP Webcam C600, utilisez notre manuel de réparation.
  1. Buy a Logitech 2-MP Webcam C600, model number: 960-000395 Remove Camera from the box Pull to remove the base
  2. Pry off the button mounted on the side Green arrow indicates the location of screw hole Use a #0 Phillips head screwdriver to remove the screw
    • Pry off the button mounted on the side
    • Green arrow indicates the location of screw hole
    • Use a #0 Phillips head screwdriver to remove the screw
  3. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  4. Remove the screw indicated by  the green arrows The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
    • Remove the screw indicated by the green arrows
    • The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
  5. The screws indicated by the blue arrows hold the lens module in place The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass. The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
    • The screws indicated by the blue arrows hold the lens module in place
    • The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
  6. Attached to the white plastic is the privacy shade position sensor. The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
    • Attached to the white plastic is the privacy shade position sensor.
    • The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
    • The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
I Heart Robotics
Membre depuis le 09/11/2009
210 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 19
Total : 25,980
