Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Logitech K700 Keyboard, utilisez notre manuel de réparation.
  1. Turn the keyboard over and slide the battery cover in the direction of the arrows slightly, and then lift the cover away.
    • Turn the keyboard over and slide the battery cover in the direction of the arrows slightly, and then lift the cover away.
  2. Remove the batteries and the two screws shown.
    • Remove the batteries and the two screws shown.
  3. Use a thumbnail or a pick to separate the clips around the periphery between the black and white plastic parts.
    • Use a thumbnail or a pick to separate the clips around the periphery between the black and white plastic parts.
    • There are 4 clips on the top, 2 on either side, and 5 along the bottom. If you do the sides and top first, the bottom should slide out.
    • Don't separate the top and bottom immediately, since there are a couple of cables (near the touch pad) that connect between the two.
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  5. The smaller of the two cables is for the touchpad.  Lift the catch on its connector in order to slide it out.
    • The smaller of the two cables is for the touchpad. Lift the catch on its connector in order to slide it out.
    • The larger cable is for the key matrix. Just pull it out from the connector (friction fit).
    • This is as far as you can easily disassemble the keyboard. To go further requires removing 12 screws and 35 plastic rivets. This is not recommended.
    • To clean the keyboard of liquid, I suggest holding it over a sink with the touchpad side up, then spraying plenty of isopropyl alcohol from the back, avoiding the touch-pad area (you may wish to mask it off). Let dry completely before reassembling.
    • If keys still do not function after cleaning, then it is possible that traces on the key matrix have become corroded. This is not repairable, since the key matrix is a sealed unit. It consists of 3 layers of plastic that are sealed together. Unfortunately, it is not 100% sealed to prevent entry of liquids.
  6. Should you go further and remove the 12 screws and 35 plastic rivets, you can see this.
    • Should you go further and remove the 12 screws and 35 plastic rivets, you can see this.
  7. The keys can be popped out easily enough by pushing from the back side.  This exposes the key matrix.
    • The keys can be popped out easily enough by pushing from the back side. This exposes the key matrix.
  8. Here is the key matrix in all its glory.
    • Here is the key matrix in all its glory.
cityzen
Membre depuis le 03/05/2010
3 928 Réputation
2 tutoriels rédigés
Very helpful! I combined this and cleaning the battery compartments with a white vinegar drenched Q-Tip to clean out some old battery corrosion, and now it turns on!
mpeterfin - Réponse
Voir les statistiques:
Dernières 24 heures : 15
7 derniers jours : 48
30 derniers jours : 216
Total : 9,532
