Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Logitech M Series Mouse, utilisez notre manuel de réparation.
  1. Logitech M235 Teardown, Logitech M235 Teardown: étape 1, image 1 de 1
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: étape 2, image 1 de 2 Logitech M235 Teardown: étape 2, image 2 de 2
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: étape 3, image 1 de 1
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: étape 4, image 1 de 1
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: étape 5, image 1 de 1
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: étape 6, image 1 de 1
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: étape 7, image 1 de 1
    • Done!
Daniel
Membre depuis le 11/27/16
225 Réputation
1 tutoriel rédigé
Équipe
4Bits Repairs Membre de l'équipe 4Bits Repairs
Business
1 membre
2 tutoriels rédigés
8 commentaires
Great work. Hope to see some more of your work
Mustafa karu - Réponse
thank you..this helped me a looot
Sharnav Kundu - Réponse
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Réponse
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Réponse
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 74
Total : 21,822
