Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. Logitech S120 Slim Mini Stereo Speakers Teardown, Logitech S120 Slim Mini Stereo Speakers Teardown: étape 1, image 1 de 1
    • Desktop Computer Speakers
    • Weight: 1lb
    • Height: 6.22 in
    • Width: 2.67 in
    • Depth: 2.51 in
    • Power: 2.2W (RMS)
    • RCA and 3.5mm jack inputs
  2. Logitech S120 Slim Mini Stereo Speakers Teardown, Remove Speaker Grill: étape 2, image 1 de 1
    • Remove the speaker grills using a thin, flat object such as a flathead screwdriver.
    • Insert the tool where the grill connects to the chassis just above the logitech logo.
    • Pry upwards until the grill releases
  3. Logitech S120 Slim Mini Stereo Speakers Teardown, Open the Speaker Chassis: étape 3, image 1 de 1
    • Insert the flathead screwdriver in the seam between the speaker chassis.
    • Use force to jam the flathead screwdriver into the chassis.
    • Drag the screwdriver around the chassis until the two sides separate.
  4. Logitech S120 Slim Mini Stereo Speakers Teardown, Remove Internal Components: étape 4, image 1 de 1
    • Using a phillips head screwdriver, remove the screws holding the PCB, transformer, and speakers to the chassis.
    • Pull the PCB, transformer, and speakers from the chassis.
  5. Logitech S120 Slim Mini Stereo Speakers Teardown, Examine Speaker Driver: étape 5, image 1 de 1
    • The driver board contains several components
    • Stereo Amplifier: TEA2025B
    • 5mm LED power indicator
    • Potentiometer and on/off switch
    • Decoupling, bypass, and AC coupling capcaitors
bglidden95
Membre depuis le 02/14/14
130 Réputation
1 tutoriel rédigé
3 commentaires
I took mine apart, only the Speaker that contains the On/Off Volume— Potentiometer. That Speaker fell off my table and hit the floor landing on the Volume control knob, since then the Speakers do not work unless I insert something to keep pressure on the Volume Control’s shaft. Is it possible to obtain and replace the potentiometer/On/Off Switch…?
James L Parmenter - Réponse
Yeah. Same here. I was blown away of the fact that there are no trasistors. Zero. None.
There is one IC chip, SC1863. But I cant find info on it.
Actually I just want to use it as a portable usb powered guitar amp. But I cant get my head around no transistors in it. Weird, huh?
Siggy Retburns -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 66
Total : 7,332
