Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: étape 1, image 1 de 2 M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: étape 1, image 2 de 2
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
  2. M8s OTT TV BOX  Teardown, Remove the bottom: étape 2, image 1 de 3 M8s OTT TV BOX  Teardown, Remove the bottom: étape 2, image 2 de 3 M8s OTT TV BOX  Teardown, Remove the bottom: étape 2, image 3 de 3
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
  3. M8s OTT TV BOX  Teardown: étape 3, image 1 de 3 M8s OTT TV BOX  Teardown: étape 3, image 2 de 3 M8s OTT TV BOX  Teardown: étape 3, image 3 de 3
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
  4. M8s OTT TV BOX  Teardown, Remove the LED board: étape 4, image 1 de 1
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: étape 5, image 1 de 2 M8s OTT TV BOX  Teardown, Remove the steel heat plate: étape 5, image 2 de 2
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
Austin Pollard
Membre depuis le 02/05/17
1 474 Réputation
3 tutoriels rédigés
Équipe
Reno Phone Repair Membre de l'équipe Reno Phone Repair
Business
1 membre
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 20
Total : 2,202
