Introduction
Outline what you are going to teach someone how to do.
Ce dont vous avez besoin
Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
With your Phillips head screwdriver, remove the 3 screws that hold it in place.
The device has been effectively disassembled.
