Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Mac Pro 2009-2012, utilisez notre manuel de réparation.
  1. Mac Pro 2009-2012 Teardown, Open the Case: étape 1, image 1 de 3 Mac Pro 2009-2012 Teardown, Open the Case: étape 1, image 2 de 3 Mac Pro 2009-2012 Teardown, Open the Case: étape 1, image 3 de 3
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Teardown, Remove the side panel: étape 2, image 1 de 2 Mac Pro 2009-2012 Teardown, Remove the side panel: étape 2, image 2 de 2
    • Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
  3. Mac Pro 2009-2012 Teardown, Remove the hard drives: étape 3, image 1 de 2 Mac Pro 2009-2012 Teardown, Remove the hard drives: étape 3, image 2 de 2
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Teardown, Remove the DVD drives: étape 4, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the DVD drives: étape 4, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the DVD drives: étape 4, image 3 de 3
    • Pull the DVD drives towards you, just like the hard drives.
  5. Mac Pro 2009-2012 Teardown, Remove the CPU board: étape 5, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU board: étape 5, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU board: étape 5, image 3 de 3
    • Press both latches to unlock the bracket and then pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Teardown, Disconnect the GPU: étape 6, image 1 de 2 Mac Pro 2009-2012 Teardown, Disconnect the GPU: étape 6, image 2 de 2
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): étape 7, image 1 de 3 Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): étape 7, image 2 de 3 Mac Pro 2009-2012 Teardown, Disconnect the GPU power supply ( Optional ): étape 7, image 3 de 3
    • On the power supply there is a button, press it to move the power supply to the left (see picture)
    • Then pull the graphics card towards you to take it out of the box
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): étape 8, image 1 de 2 Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): étape 8, image 2 de 2
    • Disconnect the PCI-e cables from the motherboard
    • This step is optional depending on your Mac Pro
  9. Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: étape 9, image 1 de 3 Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: étape 9, image 2 de 3 Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: étape 9, image 3 de 3
    • With a screwdriver unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you
  10. Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: étape 10, image 1 de 2 Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: étape 10, image 2 de 2
    • Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Teardown, Unscrew CPU support: étape 11, image 1 de 3 Mac Pro 2009-2012 Teardown, Unscrew CPU support: étape 11, image 2 de 3 Mac Pro 2009-2012 Teardown, Unscrew CPU support: étape 11, image 3 de 3
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: étape 12, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: étape 12, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: étape 12, image 3 de 3
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: étape 13, image 1 de 2 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: étape 13, image 2 de 2
    • Similar to the top remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: étape 14, image 1 de 3 Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: étape 14, image 2 de 3 Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: étape 14, image 3 de 3
    • Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step or you risk damaging your connectors on the motherboard and make unusable fans and speaker!
  15. Mac Pro 2009-2012 Teardown, Remove the CPU Support: étape 15, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU Support: étape 15, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the CPU Support: étape 15, image 3 de 3
    • Pull the CPU support towards you
    • Do not use force during this step,It it does not come out easily ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Teardown, Remove the expansion card connector: étape 16, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the expansion card connector: étape 16, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the expansion card connector: étape 16, image 3 de 3
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Attention, it is necessary to remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Teardown, Remove the expansion card: étape 17, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the expansion card: étape 17, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the expansion card: étape 17, image 3 de 3
    • Unscrew the 6 screws that hold the card in place.
    • Be careful to unplug the power cable on the card !!
  18. Mac Pro 2009-2012 Teardown, Remove the cover: étape 18, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the cover: étape 18, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the cover: étape 18, image 3 de 3
    • unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Teardown, Unplug the power supply: étape 19, image 1 de 3 Mac Pro 2009-2012 Teardown, Unplug the power supply: étape 19, image 2 de 3 Mac Pro 2009-2012 Teardown, Unplug the power supply: étape 19, image 3 de 3
    • Push on both knobs to remove the power connector
    • Do not use force, if you are struggling ensure you are squeezing the clips adequately.
  20. Mac Pro 2009-2012 Teardown, Separate the power supply: étape 20, image 1 de 2 Mac Pro 2009-2012 Teardown, Separate the power supply: étape 20, image 2 de 2
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Teardown, Remove the power supply: étape 21, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the power supply: étape 21, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the power supply: étape 21, image 3 de 3
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: étape 22, image 1 de 3 Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: étape 22, image 2 de 3 Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: étape 22, image 3 de 3
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Teardown, Remove the mother board: étape 23, image 1 de 3 Mac Pro 2009-2012 Teardown, Remove the mother board: étape 23, image 2 de 3 Mac Pro 2009-2012 Teardown, Remove the mother board: étape 23, image 3 de 3
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Teardown, Change the case: étape 24, image 1 de 1
    • Follow the steps in reverse to resemble.
Ben Capehart
Membre depuis le 06/09/21
9 329 Réputation
19 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 697 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 77
30 derniers jours : 298
Total : 4,940
