Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre MacBook Pro 15" Retina Display Mid 2015, utilisez notre manuel de réparation .
The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Lift the end of the SSD up enough to pass over the speaker directly behind it.
Do not lift the SSD too high, or you could damage the contacts or socket.
Pull the SSD straight out of its socket on the logic board.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Étape unique
Tutoriel complet
Petit - 600 px
Moyen - 800 px
Grand - 1200 px
Aperçu
