Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Mele F10, utilisez notre manuel de réparation.
  1. 2.4GHz wireless frequency Max. control range: 30 meters IR remote range: 10 meters
    • 2.4GHz wireless frequency
    • Max. control range: 30 meters
    • IR remote range: 10 meters
    • Built-in 500mAh battery
  2. There is no screws. I have opened remote only by hands by bendig edges There is no screws. I have opened remote only by hands by bendig edges
    • There is no screws. I have opened remote only by hands by bendig edges
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. OK! let see what parts we have inside nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • OK! let see what parts we have inside
    • nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
    • ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
    • IR TX diode
  5. More parts JTAG ? Mini-USB port - as far as I know can be used only to charging
    • More parts
    • JTAG ?
    • Mini-USB port - as far as I know can be used only to charging
    • 500mAh battery
  6. USB Receiver nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
    • USB Receiver
    • nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Adam
Membre depuis le 12/10/2011
128 Réputation
1 tutoriel rédigé
Super! Thank you
nisko84 - Réponse
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
Jose Manuel Peinado Navarro - Réponse
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
http://forum.mele.cn/showthread.php?tid=...
drdedus - Réponse
Confirm not work with Panasonic TV
Aurel Enache -
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Amine Elsemine - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 69
Total : 10,457
