Aller au contenu principal
Motorola Moto G3 Teardown
Ce dont vous avez besoin
Vidéo d'introduction
  1. Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: étape 1, image 1 de 2 Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: étape 1, image 2 de 2
    • Remove back cover.
    • Moto G3 plastic panel can be easily removed with the fingernails.
  2. Motorola Moto G3 Teardown: étape 2, image 1 de 2 Motorola Moto G3 Teardown: étape 2, image 2 de 2
    • Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
  3. Motorola Moto G3 Teardown: étape 3, image 1 de 2 Motorola Moto G3 Teardown: étape 3, image 2 de 2
    • Undo 3 screws by T4 Torx screwdriver.
    • Take away plastic securing part.
  4. Motorola Moto G3 Teardown: étape 4, image 1 de 3 Motorola Moto G3 Teardown: étape 4, image 2 de 3 Motorola Moto G3 Teardown: étape 4, image 3 de 3
    • Heat up the LCD screen for a while.
    • Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
    • There is LCD screen connector on the left side, so be careful to slide guitar picks.
  5. Motorola Moto G3 Teardown: étape 5, image 1 de 3 Motorola Moto G3 Teardown: étape 5, image 2 de 3 Motorola Moto G3 Teardown: étape 5, image 3 de 3
    • Release LCD screen connector firstly.
    • Remove LCD screen.
  6. Motorola Moto G3 Teardown: étape 6, image 1 de 3 Motorola Moto G3 Teardown: étape 6, image 2 de 3 Motorola Moto G3 Teardown: étape 6, image 3 de 3
    • Undo 14 screws by T4 Torx screwdriver
    • Pry up motherboard assembly.
    • Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
  7. Motorola Moto G3 Teardown: étape 7, image 1 de 2 Motorola Moto G3 Teardown: étape 7, image 2 de 2
    • Release battery flex connector.
    • Separate motherboard assembly from back cover assembly.
  8. Motorola Moto G3 Teardown: étape 8, image 1 de 3 Motorola Moto G3 Teardown: étape 8, image 2 de 3 Motorola Moto G3 Teardown: étape 8, image 3 de 3
    • Undo 3 screws here.
    • Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
  9. Motorola Moto G3 Teardown: étape 9, image 1 de 2 Motorola Moto G3 Teardown: étape 9, image 2 de 2
    • Remove front-facing camera.
  10. Motorola Moto G3 Teardown: étape 10, image 1 de 3 Motorola Moto G3 Teardown: étape 10, image 2 de 3 Motorola Moto G3 Teardown: étape 10, image 3 de 3
    • Remove rear camera.
  11. Motorola Moto G3 Teardown: étape 11, image 1 de 2 Motorola Moto G3 Teardown: étape 11, image 2 de 2
    • Remove earpiece.
  12. Motorola Moto G3 Teardown: étape 12, image 1 de 2 Motorola Moto G3 Teardown: étape 12, image 2 de 2
    • Remove loudspeaker.
  13. Motorola Moto G3 Teardown: étape 13, image 1 de 2 Motorola Moto G3 Teardown: étape 13, image 2 de 2
    • Here is the motherboard.
  14. Motorola Moto G3 Teardown: étape 14, image 1 de 2 Motorola Moto G3 Teardown: étape 14, image 2 de 2
    • Use spudger to cut adhesive and pry the battery up.
  15. Motorola Moto G3 Teardown: étape 15, image 1 de 3 Motorola Moto G3 Teardown: étape 15, image 2 de 3 Motorola Moto G3 Teardown: étape 15, image 3 de 3
    • Take away headphone jack.
  16. Motorola Moto G3 Teardown: étape 16, image 1 de 1
    • Done
Ligne d'arrivée
17 autres ont terminé cette réparation.
Witrigs
Membre depuis le 11/24/15
69 151 Réputation
378 tutoriels rédigés
7 commentaires
Muito bom, parabéns!
Manoel - Réponse
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
setsuoleandro - Réponse
Wi fi not trun on ..moto g3
Seoni Seoni - Réponse
When you heat up the display, do you heat up the entire display or just around the edges? What heat gun/setting should i use? Can i use a blowdryer?
guest - Réponse
Thanks. ......................
Biswajit Saha - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 36
Total : 23,738
