Introduction
Wanna know how to disassemble Motorola Moto X Force? Here show detailed steps.
Ce dont vous avez besoin
Use heat gun to heat up back cover firstly.
Insert metal opening tool to open a gap and cut adhesives around.
Twist off 17 screws by T3 Torx screwdriver.
Take away rubber bracket securing NFC antenna and release NFC antenna connector.
After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
Release MIC connector.
There are adhesives existed underneath.
There are a little bit adhesives around, but you can peel this part easily.
Peel off the tape.
Twist off 2 screws.
Release this two connectors carefully.
The LCD assembly has two connectors, here is touchscreen connector.
Release signal cable connector.
Pry the motherboard assembly up.
Use tweezers to release the connector.
With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
Be careful to pry this part up, because it tends to fall apart easily.
9 commentaires
>>Here is LCD screen with LCD supporting frame.
amoled
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
