Outils recommandés dans ce démontage
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Mr. Coffee DW13, utilisez notre manuel de réparation.
By unscrewing the bottom of the drip coffee maker we get access to its internals. By unscrewing the bottom of the drip coffee maker we get access to its internals.
  • By unscrewing the bottom of the drip coffee maker we get access to its internals.
Ajouter un commentaire
Taking out the 2 screws shown in the image unlocks the water heater, temperature regulator, and pot heater.
  • Taking out the 2 screws shown in the image unlocks the water heater, temperature regulator, and pot heater.
The red arrows represent the path of the electricity.
  • The red arrows represent the path of the electricity.
  • The electricity travels from the power cord to the switch where they both connect. When the switched is turned on the power goes from the switch to 2 places.
  • The 1st place it goes is to a giant resistor under the metal pipe that transports the water. This resistor is the pot heater and water heater.
  • The 2nd place the power goes is to a temperature regulator, which makes sure the temperature of the water and the pot don't go above a certain point.
The way the coffee drip  works is water travels through the rubber tubes through a metal pipe getting heated.
  • The way the coffee drip works is water travels through the rubber tubes through a metal pipe getting heated.
  • The water can't travel upward so it gets stuck around the temperature regulator where it boils. Once boiled the steam pushes the remaining water left up the tube into the coffee pot.
  • This process repeats over and over again until the switch closing the circuit opens up again
ThatDoodNate
Membre depuis le 15/04/2018
379 Réputation
2 tutoriels rédigés
Thank you so much to this useful info windows remote desktop i like to learn through this share with other needed users of windows 10 OS. With this remote facility you will able to work at your desktop with lots of interest. Get this homepage and learn the process.
ashwin kumar - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 37
Total : 291
