Aller au contenu principal
Outils recommandés dans ce démontage
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nespresso CitiZ, utilisez notre manuel de réparation.
  1. The CitiZ is a compact coffee-making gizmo. Opening it requires a proprietary tool that Nespresso doesn't sell.
    • The CitiZ is a compact coffee-making gizmo. Opening it requires a proprietary tool that Nespresso doesn't sell.
    • You can get into it with a pair of needle-nose pliers. The pliers I used aren't ideal — you want something that can get into the recessed slots.
  2. There are six ovoid screws on the bottom case. The screws look like rivets, but they are actually oval.
  3. Now that the screws are removed, use a screwdriver or a spudger to pry the tabs holding the bottom case on. The easiest place to get in is the power plug. Be careful not to nick it. (And make sure you're unplugged from the wall!) The easiest place to get in is the power plug. Be careful not to nick it. (And make sure you're unplugged from the wall!)
    • Now that the screws are removed, use a screwdriver or a spudger to pry the tabs holding the bottom case on.
    • The easiest place to get in is the power plug. Be careful not to nick it. (And make sure you're unplugged from the wall!)
  4. Carefully open the lower case and set the machine on its side.
    • Carefully open the lower case and set the machine on its side.
  5. The plastic strain relief bracket on the power cable is challenging to remove. Insert a small flathead screwdriver into the small slot on one side to disengage the tab.
    • The plastic strain relief bracket on the power cable is challenging to remove. Insert a small flathead screwdriver into the small slot on one side to disengage the tab.
  6. Nespresso makes heavy use of spade connectors inside this machine.
    • Nespresso makes heavy use of spade connectors inside this machine.
    • Grab one side firmly with your pliers and pull on the other side of the connector with your fingers. Do not pull on the cable, because you can pull it free from the spade connector.
  7. Disconnect the blue neutral wire.
    • Disconnect the blue neutral wire.
    • Remove the power switch from the case.
  8. Firmly grasp the power cable connectors and remove them from the power switch.
    • Firmly grasp the power cable connectors and remove them from the power switch.
  9. Insert the tip of a spudger into the silicon tube and slide it off the nipple.
    • Insert the tip of a spudger into the silicon tube and slide it off the nipple.
  10. Thread the remaining tubes and wires through the bottom case to free it from the main unit. Remove the bottom case.
    • Thread the remaining tubes and wires through the bottom case to free it from the main unit.
    • Remove the bottom case.
  11. Removing the outer shell requires some force. There are a series of tabs on all four sides of the shell. Start by using a flathead screwdriver or spudger to pop the first tab.
    • Removing the outer shell requires some force.
    • There are a series of tabs on all four sides of the shell.
    • Start by using a flathead screwdriver or spudger to pop the first tab.
    • Work your way around the case, freeing tabs as you go.
  12. Keep prying! Keep prying! Keep prying!
    • Keep prying!
  13. Remove the outer shell.
    • Remove the outer shell.
  14. Extricate the control button wires from the case assembly.
    • Extricate the control button wires from the case assembly.
  15. Remove the blue tube from the flow meter. This part, which measures water flow, is referred to as a 'debimetre' in Nespresso's part lists. It is part # 932-9521.
    • Remove the blue tube from the flow meter.
    • This part, which measures water flow, is referred to as a 'debimetre' in Nespresso's part lists. It is part # 932-9521.
    • Remove the sensor data cable.
  16. The pump feed tube uses a clever retaining clip. Remove this clip with your pliers. It does not require much force.
    • The pump feed tube uses a clever retaining clip. Remove this clip with your pliers. It does not require much force.
    • Repeat this for the clip attaching the valve to the water heater.
  17. Remove the valve assembly from the frame.
    • Remove the valve assembly from the frame.
  18. Disconnect the power cable from the spade connector on the side of the water pump.
    • Disconnect the power cable from the spade connector on the side of the water pump.
  19. Remove the side panel from the other side of the unit. The tab positions are similar to the first side panel.
    • Remove the side panel from the other side of the unit. The tab positions are similar to the first side panel.
  20. Disengage the tabs holding the top assembly to the case. Disengage the tabs holding the top assembly to the case. Disengage the tabs holding the top assembly to the case.
    • Disengage the tabs holding the top assembly to the case.
  21. Remove the front spout. Remove the top case. Be careful, the button cables are captive to the case. Disentangle the cables and set the top next to the frame.
    • Remove the front spout.
    • Remove the top case. Be careful, the button cables are captive to the case. Disentangle the cables and set the top next to the frame.
    • You will not be able to completely remove the top case until the circuit board is removed. (The button cables do not disconnect from the main circuit board.)
  22. Remove the plastic outer circuit board cover.
    • Remove the plastic outer circuit board cover.
  23. Power cables, from left to right: heat (white), neutral (blue), pump (dark grey), pump ground? (light grey), line (brown). Disconnect each cable with your pliers.
    • Power cables, from left to right: heat (white), neutral (blue), pump (dark grey), pump ground? (light grey), line (brown).
    • Disconnect each cable with your pliers.
  24. Slide the water pump out. The rubber vibration isolator doubles as a mounting bracket that neatly slides out from the plastic frame. Slide the water pump out. The rubber vibration isolator doubles as a mounting bracket that neatly slides out from the plastic frame.
    • Slide the water pump out. The rubber vibration isolator doubles as a mounting bracket that neatly slides out from the plastic frame.
  25. Remove the (rather over-engineered) silicon mounting bracket holding the coffee feed line in place.
    • Remove the (rather over-engineered) silicon mounting bracket holding the coffee feed line in place.
  26. Disconnect the latches and slide the heating assembly out of the frame.
    • Disconnect the latches and slide the heating assembly out of the frame.
  27. Free the latch on the right side of the circuit board and then carefully lever it out. Don't use too much force on the plastic bracket on top of the circuit board because there are two vulnerable capacitors on the rear left side of the board.
    • Free the latch on the right side of the circuit board and then carefully lever it out.
    • Don't use too much force on the plastic bracket on top of the circuit board because there are two vulnerable capacitors on the rear left side of the board.
  28. The remaining cables can not be removed from the board. Don't try!
    • The remaining cables can not be removed from the board. Don't try!
  29. The BTB12 AC 12 Amp triac requires a large heat sink that is riveted onto the main board.
    • The BTB12 AC 12 Amp triac requires a large heat sink that is riveted onto the main board.
  30. Voilá!
    • Voilá!
28 commentaires
A tool or a bit for those oval-head screws can often be bought at suppliers for coffee automates e.g. branded "Jura", "AEG", "Siemens", "Krups"
VauWeh - Réponse
Where is the heating element then?
Junhao Eric Tan - Réponse
Hi Junaho.
Did you have a look to Step 26 ?
Christophe S - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 152
30 derniers jours : 920
Total : 90,010
