Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nikko La Nera Junior, utilisez notre manuel de réparation.
  1. The Car, the Remote Control and a Phillips screwdriver.
    • The Car, the Remote Control and a Phillips screwdriver.
  2. Let's start!
    • Let's start!
    • Remove this screw.
  3. The rear wing Unscrew this black screws
    • The rear wing
    • Unscrew this black screws
    • Remove the wing
  4. The Exhausts Remove these screws Remove the exhausts
    • The Exhausts
    • Remove these screws
    • Remove the exhausts
  5. The Rear Cover
    • The Rear Cover
  6. The "tubolar" body Flip the car
    • The "tubolar" body
    • Flip the car
    • Remove these screws.
    • Remove the body
  7. The seat Remove these screws (one of these is back of the seat)
    • The seat
    • Remove these screws (one of these is back of the seat)
    • Remove the seat.
  8. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  9. The antenna Remove this screw Raise the circuit board
    • The antenna
    • Remove this screw
    • Raise the circuit board
    • Remove the antenna
  10. The "engine" Remove these screws
    • The "engine"
    • Remove the gears cover
    • Remove the engine block
  11. Remove the gear and his hinge Remove this piece of plastic The Engine!
    • Remove the gear and his hinge
    • Remove this piece of plastic
    • The Engine!
  12. Remove the wheels from the car
    • Remove the wheels from the car
  13. The Steering Mechanism Remove these screws Remove the cover
    • The Steering Mechanism
    • Remove the cover
    • Lift the wheels
  14. Remove the steering bar... ...the two screws...
    • Remove the steering bar...
    • ...the two screws...
    • ...and the cover.
  15. Remove the first "gear"... ...and the second.
    • Remove the first "gear"...
    • ...and the second.
  16. Remove the steering motor Remove the plastic cover Be careful!
    • Remove the steering motor
    • Remove the plastic cover
    • Be careful!
    • Remove this piece
  17. Remove the second piece...
    • Remove the second piece...
    • ...and the spring.
    • Congratulations! The car is torn down!
  18. Let's tear down the remote! Remove these screws
    • Let's tear down the remote!
  19. Remove the screw in the PCB Remove the screw in the piece of plastic at the end of the antenna Remove the plastic piece around the beginning of the antenna
    • Remove the screw in the PCB
    • Remove the screw in the piece of plastic at the end of the antenna
    • Remove the plastic piece around the beginning of the antenna
  20. Carefully de-route the antenna from the PCB Carefully de-route the antenna from the PCB Carefully de-route the antenna from the PCB
    • Carefully de-route the antenna from the PCB
  21. Detach the two parts of eat key. Congratulations! You've ended the teardown!
    • Detach the two parts of eat key.
    • Congratulations! You've ended the teardown!
Federico Barutto
Membre depuis le 12/06/2011
306 Réputation
2 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 1,424
