Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nintendo DSi, utilisez notre manuel de réparation.
  1. Nintendo DSi Teardown, Nintendo DSi Teardown: étape 1, image 1 de 2 Nintendo DSi Teardown, Nintendo DSi Teardown: étape 1, image 2 de 2
    • It's here! It's here! Whoopee!
    • Contents of the box:
    • Nintendo DSi
    • Operation Manual
    • Quick Start Guide
    • AC Adapter
    • Extra Stylus
    • An invitation from Mario's hat to join Club Nintendo.
  2. Nintendo DSi Teardown: étape 2, image 1 de 1
    • Oooh pretty colors!
    • The manual is larger in every dimension than the DSi except for thickness. Many of the pages are in color... That's probably why the DSi costs so much more than its forebear.
  3. Nintendo DSi Teardown: étape 3, image 1 de 2 Nintendo DSi Teardown: étape 3, image 2 de 2
    • A side by side comparison of the Nintendo DS Lite (left) and the Nintendo DSi (right).
    • The DSi has a new skin: a matte-black (almost dark gray) color that feels much rougher than the DS Lite. The roughness allows for better grip of the system, as well as improved scratch resistance.
    • The DSi is 3 mm thinner than the DS Lite, while its length and width increase by 4 mm and 1 mm, respectively.
    • The DSi comes with 3.25" LCD panels, a full 0.25" larger than the previous model's 3" panels.
  4. Nintendo DSi Teardown: étape 4, image 1 de 2 Nintendo DSi Teardown: étape 4, image 2 de 2
    • Two Phillips screws prevent access to the battery. They are easily dealt with using our custom-made screwdriver.
    • A quick flick of the spudger (or fingernail) dislocates the battery from its housing.
  5. Nintendo DSi Teardown: étape 5, image 1 de 1
    • There are a total of seven screws that hold the lower case of the DSi together:
    • Three are immediately visible without removing any plug or cover.
    • Two plugs near the top of the unit have to be removed to reveal two screws.
    • Removal of the battery compartment reveals two additional screws that need to be removed.
  6. Nintendo DSi Teardown: étape 6, image 1 de 1
    • And just like that, the case comes open.
    • An orange connector joins the cases together. Care should be taken when opening the DSi to ensure this connector is not damaged in the process.
  7. Nintendo DSi Teardown: étape 7, image 1 de 1
    • A comparison between the old and the new. There are definite differences between the DS Lite (left) and DSi (right).
    • The DSi uses a smaller 840mAh rechargeable battery (right) compared to 1000mAh for the DS Lite (left). The difference in size is proportionate to the difference in capacity. The original Nintendo DS shipped with an 850mAh battery.
  8. Nintendo DSi Teardown: étape 8, image 1 de 1
    • Removing the battery PCB is a pretty straightforward procedure:
    • Disconnect three connectors.
    • Unscrew five Phillips screws.
  9. Nintendo DSi Teardown: étape 9, image 1 de 2 Nintendo DSi Teardown: étape 9, image 2 de 2
    • The Wi-Fi board is held in place via one large connector. A quick wedge-and-twist action of the spudger releases it from the main board.
    • Another flick of the spudger removes the Wi-Fi board's connector wire.
  10. Nintendo DSi Teardown: étape 10, image 1 de 2 Nintendo DSi Teardown: étape 10, image 2 de 2
    • The main board comes off almost as easily as the battery PCB:
    • Four Phillips screws need to be removed.
    • Six connectors need to be disconnected prior to removal: five on the visible side, and one on the other side.
  11. Nintendo DSi Teardown: étape 11, image 1 de 1
    • We are done with the first level of the disassembly.
  12. Nintendo DSi Teardown: étape 12, image 1 de 2 Nintendo DSi Teardown: étape 12, image 2 de 2
    • Four black plastic covers need to be removed to reveal the Phillips screws underneath.
    • Removing the four Phillips screws allows access to the top display.
  13. Nintendo DSi Teardown: étape 13, image 1 de 2 Nintendo DSi Teardown: étape 13, image 2 de 2
    • The upper half with outer case removed.
    • The antenna board for Wireless LAN is mounted in the upper right corner of the chasis.
    • The ribbon cables for the top display and cameras are coiled and routed through the hinge between case halves. We'll go ahead and add that to the list of parts we want to watch a robot assemble.
    • The thin orange wire seen in the second photo is for the microphone. Little DJs everywhere will drool over a new feature allowing users to distort the pitch and speed of music during playback.
  14. Nintendo DSi Teardown: étape 14, image 1 de 1
    • The DSi has two VGA CMOS digital cameras (0.3 megapixels); one on the internal hinge pointed towards the user and the other in the outer shell.
  15. Nintendo DSi Teardown: étape 15, image 1 de 2 Nintendo DSi Teardown: étape 15, image 2 de 2
    • Eight Phillips screws secure the battery compartment and the stylus tray/SD/SDHC expansion slot to the case.
    • The DSi has an integrated SD/SDHC expansion slot. You can now use a normal SD card for the playback of AAC audio files and external storage of pictures or downloaded software. Can anyone say homebrew apps?
  16. Nintendo DSi Teardown: étape 16, image 1 de 3 Nintendo DSi Teardown: étape 16, image 2 de 3 Nintendo DSi Teardown: étape 16, image 3 de 3
    • The logic board in its full glory.
    • Chips of interest, left to right:
    • Samsung 1st generation MoviNAND KMAPF0000M: 256 MB NAND Flash and MMC controller. The integrated MMC controller allows the CPU to offload the complex work of directly talking to the flash memory.
    • 82DBS08164D-70L: Fujitsu Ltd 128-bit FCRAM (fast-cycle RAM) chip.
    • Nintendo's custom ARM CPU. Our CPU was manufactured in September of 2008.
  17. Nintendo DSi Teardown: étape 17, image 1 de 2 Nintendo DSi Teardown: étape 17, image 2 de 2
    • Nintendo DSi... REST IN PIECES!
    • Chips of interest:
10 commentaires
This is Nintendo DSi Teardown
Fotini Grotenbreg - Réponse
Wow I never would have guessed that
Gigabit87898 -
Hello, how do you close the system after opening it?
When I opened my dsi to clean the L and R buttons, I removed the case from the top,opposite of what you did. I dont know how to reconnect that small orange ribbon! <:(
Teto - Réponse
I would like to contribute to iFixit by doing a 3DS XL Teardown. (2012), but i do not have the console.
Santi12008 - Réponse
You should be careful when removing the L button assembly and moving a case. There’s a small square pocket in the case which houses a small square nut which is where the top screw from the battery lid fastens to. The black piece that keeps the L shoulder button assembly in place also holds this nut. Once you remove it, the nut is free to come out and can be easily lost.
BrunoDSL - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 23
7 derniers jours : 223
30 derniers jours : 1,017
Total : 324,767
