Aller au contenu principal
Outils recommandés dans ce démontage
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nokia 2605, utilisez notre manuel de réparation.
  1. Red arrows indicate which screws must be removed in order to get to the motherboard.
    • Red arrows indicate which screws must be removed in order to get to the motherboard.
  2. Take T5 torx and remove all 3 screws.
    • Take T5 torx and remove all 3 screws.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • As you move toward the top, remove the camera and volume buttons.
  5. Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip). Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
    • Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
Dorsa
Membre depuis le 07/11/2013
143 Réputation
1 tutoriel rédigé
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,025
