Outils recommandés dans ce démontage
Introduction
I'm going to open my old Nokia phone to have a look.But I only have very limited English writing skills and I hope you'll understand what I'm talking about.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nokia 6108, utilisez notre manuel de réparation.
  1. Hello,I'm going to open my phone for some fun.
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Remove the following parts. Battery cover
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Remove the front panel by pulling it or using an I don't have a opening tool.So I used a flathead screw driver instead.
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Remove 5 trox screws that are holding the screen and the touch pad. Remove 5 trox screws that are holding the screen and the touch pad.
    • Remove 5 trox screws that are holding the screen and the touch pad.
  6. After removing the touch pad and the screen.You can remove the logic board from the case. The board seem don't want to leave its cozy home.
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  7. Let's start removing the parts under the logic board.
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  8. Removing the EMI shield.Pry around the edge of the shield to remove it.
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  9. Nothing under the EMI shield. I think we should stop here right now.There are pictures for all parts.
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
Membre depuis le 19/02/2011
322 Réputation
1 tutoriel rédigé
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 4,345
