Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nokia Asha 200, utilisez notre manuel de réparation.
  1. Nokia Asha 200 Teardown, Nokia Asha 200 Teardown: étape 1, image 1 de 1
    • Take the back cover off and remove the battery. (Not shown)
    • Remove the two screws located with red circles
  2. Nokia Asha 200 Teardown: étape 2, image 1 de 3 Nokia Asha 200 Teardown: étape 2, image 2 de 3 Nokia Asha 200 Teardown: étape 2, image 3 de 3
    • Insert spudger between the front/back case and lever untill you hear a click.
    • Slowly work your way around until the bottom end is separated. Then with the bottom end facing your body, try to pull the back case towards yourself.
    • Make sure not to loose Sim2 and Micro SD covers as they easily fall out. Also when re-assembling make sure they are pulled out otherwise you will have trouble putting things back together
  3. Nokia Asha 200 Teardown: étape 3, image 1 de 3 Nokia Asha 200 Teardown: étape 3, image 2 de 3 Nokia Asha 200 Teardown: étape 3, image 3 de 3
    • Remove the 4 screws marked with red circles
    • There are two clips now holding the circuit board in place. Maneuver the circuit board over one and then pull towards the released clip to release the opposite one.
  4. Nokia Asha 200 Teardown: étape 4, image 1 de 2 Nokia Asha 200 Teardown: étape 4, image 2 de 2
    • The lcd screen is held in by a steel bracket. This bracket is held in place by the clips marked with red squares. The easit way to release it is by levering the one on the right (as pictured) and the bracket should come off.
    • When re-assembling make sure the studs marked with blue circles line up properly.
    • Using a spudger disconnect the LCD cable.
  5. Nokia Asha 200 Teardown: étape 5, image 1 de 1
    • Congratulations you have successfully dis-assembled the phone. I hope you had as much fun tearing it apart as I did helping you along the way.
Joel
Membre depuis le 10/24/12
207 Réputation
1 tutoriel rédigé
3 commentaires
رائع جدا شكر علي المساعده
Ramy - Réponse
رائع جدا شكر فدني كتير وحقق شغفي وفضولي
Ramy - Réponse
How to re assemble it
Dilop - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 13
Total : 5,338
