Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre OWC Thunderbolt 3 Pro Dock, utilisez notre manuel de réparation.
  1. OWC Thunderbolt 3 Pro Dock Teardown, The start: étape 1, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, The start: étape 1, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, The start: étape 1, image 3 de 3
    • Flip dock upside down and remove rubber feet
  2. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: étape 2, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: étape 2, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: étape 2, image 3 de 3
    • Remove bottom plate screws and remove bottom plate
    • Make sure to use a TORX TR8 head for the bottom screws
  3. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: étape 3, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: étape 3, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: étape 3, image 3 de 3
    • Remove the mainboard and its three screws
    • Use a TORX TR8 for all of these screws
    • Make sure to unplug the fan on the other side as it is still connected to the chassis, it may need some persuasion as the connector is really in there
    • When removing the mainboard be gentle as the front I/O sits flush to the chassis otherwise you might damage it.
  4. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: étape 4, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: étape 4, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: étape 4, image 3 de 3
    • Remove the four TORX TR8 screws
    • Pry the top plate away from the main chassis, this may take some persuasion as the top plate is glued in a bit
  5. OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: étape 5, image 1 de 2 OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: étape 5, image 2 de 2
    • Remove the two TORX TR8 screws to remove the heatsink
    • It is highly recommended to clean the surface from whatever residue the thermal pad has left behind to increase longevity of the dock
  6. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: étape 6, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: étape 6, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: étape 6, image 3 de 3
    • Switch to a TORX TR10 bit for the fan screws
    • The fan model is a sunon HA40101V4-1D070-G99
    • When the screws are out the fan should just fall out
  7. OWC Thunderbolt 3 Pro Dock Teardown, Everything spread out: étape 7, image 1 de 1
  8. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: étape 8, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: étape 8, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: étape 8, image 3 de 3
    • sample text, the photos speak for themselves
    • The 10Gbe NIC is the Aquantia AQC107S-B1-C
  9. OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: étape 9, image 1 de 2 OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: étape 9, image 2 de 2
    • Insert wisdom here. - indeed
  10. OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: étape 10, image 1 de 2 OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: étape 10, image 2 de 2
    • I cant figure out how to put more than 3 pics in one step, so the ended up here.
  11. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: étape 11, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: étape 11, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: étape 11, image 3 de 3
    • Support the heatsink and line it up with the holes on the top of the chassis
    • Re-install the two TORX TR8 screws to hold in the heatsink
  12. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: étape 12, image 1 de 2 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: étape 12, image 2 de 2
    • Line up the fan with the holes
    • Screw the fan back in with the TORX TR10 screws
  13. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: étape 13, image 1 de 2 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: étape 13, image 2 de 2
    • Line up the top lid with the main chassis, make sure to have the fan vent in the correct orientation so it can breathe.
    • Screw the lid back in with the four TORX TR8 screws
  14. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: étape 14, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: étape 14, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: étape 14, image 3 de 3
    • Put the mainboard back into the main chassis, make sure to be gentile and line up the rear I/O first and then slowly lower in the other side.
    • Secure the mainboard with the 3 TORX TR8 screws. - no you arent missing any the rest of the screws go through the bottom cover
  15. OWC Thunderbolt 3 Pro Dock Teardown: étape 15, image 1 de 3 OWC Thunderbolt 3 Pro Dock Teardown: étape 15, image 2 de 3 OWC Thunderbolt 3 Pro Dock Teardown: étape 15, image 3 de 3
    • Line up the bottom cover, !make sure to use the orientation that is shown in the photo otherwise it will not line up!
    • Secure the bottom cover with the four TORX TR8 screws
    • Re-install the rubber feet, you might want to put a bit of glue on these to keep them on when moving around
Robust
Membre depuis le 04/26/21
688 Réputation
3 tutoriels rédigés
Équipe
CV22 Membre de l'équipe CV22
Community
1 membre
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 77
Total : 240
