Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Outils recommandés dans ce démontage
Introduction
Follow this guide to completely disassemble your Palm IIIc.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Palm IIIc, utilisez notre manuel de réparation.
  1. Keep track of all pieces removed from the device.
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Using a spudger, carefully pry open the front and back covers along the side seam.
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Unhook battery cable from the motherboard and remove the battery.
    • Unhook battery cable from the motherboard and remove the battery.
  5. Behind the motherboard remove the brown plastic clamp and remove the front screen cover. Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
    • Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
  6. Unhook the blue and red screen cables. Unhook the blue and red screen cables.
    • Unhook the blue and red screen cables.
  7. Pop out the other two brown plastic clamps to release the screen and buttons. Pop out the other two brown plastic clamps to release the screen and buttons. Pop out the other two brown plastic clamps to release the screen and buttons.
    • Pop out the other two brown plastic clamps to release the screen and buttons.
  8. The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
  9. Pull the screen out from the front.
    • Pull the screen out from the front.
  10. The object is now fully disassembled.
    • The object is now fully disassembled.
Paulina Trujillo
Membre depuis le 07/04/2011
241 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 20-69, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,628
