Introduction
If you've ever been curious about the particulars of a simple incandescent flashlight, this is the guide for you.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Panasonic Super Lite Flashlight, utilisez notre manuel de réparation.
  1. Twist the top assembly of the flashlight off by turning it counterclockwise above the rubber gasket.
    • Twist the top assembly of the flashlight off by turning it counterclockwise above the rubber gasket.
  2. Orient the top assembly with the lens downward to avoid dropping the bulb during this step.
    • Orient the top assembly with the lens downward to avoid dropping the bulb during this step.
    • Unscrew the bulb base by twisting counter-clockwise, taking care not to drop the bulb. Remove the bulb.
  3. Remove the rubber gasket from the top assembly.
    • Remove the rubber gasket from the top assembly.
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  5. Remove the reflector by applying pressure to one of the two protruding plastic tabs using a small flathead screwdriver while pulling on the reflector. The reflector should pop out; pull gently but firmly to avoid scattering the pieces. Remove the lens. The reflector should pop out; pull gently but firmly to avoid scattering the pieces. Remove the lens.
    • Remove the reflector by applying pressure to one of the two protruding plastic tabs using a small flathead screwdriver while pulling on the reflector.
    • The reflector should pop out; pull gently but firmly to avoid scattering the pieces. Remove the lens.
  6. Remove the batteries from the flashlight body.
    • Remove the batteries from the flashlight body.
  7. Insert the metal screwdriver as pictured: oriented vertically, underneath the yellow plastic piece in the switch assembly, between the metal contact of the switch and the gray plastic slider flange.
    • Insert the metal screwdriver as pictured: oriented vertically, underneath the yellow plastic piece in the switch assembly, between the metal contact of the switch and the gray plastic slider flange.
    • Pry upward to remove the yellow plastic piece; the metal contact piece may pop out with the plastic piece.
    • Once the metal and plastic are unseated from one side, pull out the metal contact and yellow plastic piece with pliers or fingers. Remove these pieces.
  8. Use pliers to pinch the gray flanges of the switch slider and apply pressure to push the switch out of the flashlight body.
    • Use pliers to pinch the gray flanges of the switch slider and apply pressure to push the switch out of the flashlight body.
Colin Mitchell
Membre depuis le 11/04/2011
222 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 25-26, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 2,029
