Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Pentax Optio WG-1 GPS, utilisez notre manuel de réparation.
  1. Pentax Optio WG-1 GPS Teardown, Pentax Optio WG-1 GPS: étape 1, image 1 de 1
    • Clean the device. You are able to rinse with under running water. It is recommended to ensure that you remove the battery and memory card before working with the device.
    • Prepare a clean workstation and have your tool(s) ready.
  2. Pentax Optio WG-1 GPS Teardown: étape 2, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 2, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 2, image 3 de 3
    • Remove 4 Phillips 1/4 inch 00 screws around the border of the display with the screwdriver.
  3. Pentax Optio WG-1 GPS Teardown: étape 3, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 3, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 3, image 3 de 3
    • Remove the black rubber adhesive around the border of the device by peeling slowly.
  4. Pentax Optio WG-1 GPS Teardown: étape 4, image 1 de 2 Pentax Optio WG-1 GPS Teardown: étape 4, image 2 de 2
    • Remove 2 Phillips 00 1/4 inch rubber sealed screws off the top of the camera.
  5. Pentax Optio WG-1 GPS Teardown: étape 5, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 5, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 5, image 3 de 3
    • Remove the display screen from the casing. When opening, the micro USB cover and the battery cover will fall out with a pin.
  6. Pentax Optio WG-1 GPS Teardown: étape 6, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 6, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 6, image 3 de 3
    • Remove all orange strips located on the motherboard and the LCD screen.
    • Lift black latches before removing the strips.
  7. Pentax Optio WG-1 GPS Teardown: étape 7, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 7, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 7, image 3 de 3
    • Remove the lens from the camera carefully. It is the black block held inside the casing.
  8. Pentax Optio WG-1 GPS Teardown: étape 8, image 1 de 1
    • Remove 3 Phillips 00 screws from the motherboard.
  9. Pentax Optio WG-1 GPS Teardown: étape 9, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 9, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 9, image 3 de 3
    • Remove 2 Phillips 00 screws from the mini USB bay.
  10. Pentax Optio WG-1 GPS Teardown: étape 10, image 1 de 1
    • Remove 2 Phillips 00 screws from the silver handle on the side of the camera.
  11. Pentax Optio WG-1 GPS Teardown: étape 11, image 1 de 1
    • Remove 3 Phillips 00 screws from the camera's photo capture button.
    • After removing those screws, remove the plastic piece and buttons they secure.
  12. Pentax Optio WG-1 GPS Teardown: étape 12, image 1 de 1
    • Remove 3 Phillips 00 screws from the same location located under the cameras photo capture button.
  13. Pentax Optio WG-1 GPS Teardown: étape 13, image 1 de 3 Pentax Optio WG-1 GPS Teardown: étape 13, image 2 de 3 Pentax Optio WG-1 GPS Teardown: étape 13, image 3 de 3
    • Remove the motherboard from the housing.
Brandon Berlew
Membre depuis le 01/27/15
122 Réputation
1 tutoriel rédigé
Équipe
Pasco Hernando, Team 1-3, Prince Winter 2015 Membre de l'équipe Pasco Hernando, Team 1-3, Prince Winter 2015
PHSC-PRINCE-W15S1G3
6 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 27
Total : 3,179
