Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Table Lamp, utilisez notre manuel de réparation.
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: étape 1, image 1 de 1
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: étape 2, image 1 de 1
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: étape 3, image 1 de 2 Portable Luminaries Lamp Teardown: étape 3, image 2 de 2
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: étape 4, image 1 de 2 Portable Luminaries Lamp Teardown: étape 4, image 2 de 2
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: étape 5, image 1 de 2 Portable Luminaries Lamp Teardown: étape 5, image 2 de 2
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: étape 6, image 1 de 2 Portable Luminaries Lamp Teardown: étape 6, image 2 de 2
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: étape 7, image 1 de 1
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
Brenden
Membre depuis le 11/17/14
56 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,668
