Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Punkt MP02, utilisez notre manuel de réparation.
  1. Punkt MP02 Teardown, Remove Sim card tray: étape 1, image 1 de 2 Punkt MP02 Teardown, Remove Sim card tray: étape 1, image 2 de 2
    • Remove Sim tray
  2. Punkt MP02 Teardown: étape 2, image 1 de 2 Punkt MP02 Teardown: étape 2, image 2 de 2
    • Using a knife start prying at the back in the top right corner. Then use a metal spudger to remove the back piece.
    • The back piece is held in place with a (not so strong) sticker and some hooks (see second picture for a side view of the hooks).
  3. Punkt MP02 Teardown: étape 3, image 1 de 1
    • Remove two screws.
    • in my case one of the screws was covered by a small white sticker
  4. Punkt MP02 Teardown: étape 4, image 1 de 3 Punkt MP02 Teardown: étape 4, image 2 de 3 Punkt MP02 Teardown: étape 4, image 3 de 3
    • using a metal spudger I started separating the two halves of the phone shell on the right of the USB port.
    • by carefully inserting and twisting the spudger I could unclip the two halves to separate them
    • be careful not to insert the spudger too deep, you could damage the mainboard or battery
    • as I wasn't careful enough, the frame broke in two places
  5. Punkt MP02 Teardown: étape 5, image 1 de 2 Punkt MP02 Teardown: étape 5, image 2 de 2
    • now remove the back half
    • I looks like the back contains come antennas and a speaker
  6. Punkt MP02 Teardown: étape 6, image 1 de 3 Punkt MP02 Teardown: étape 6, image 2 de 3 Punkt MP02 Teardown: étape 6, image 3 de 3
    • now remove the spongy piece that sits ontop of the USB port
    • at this stage I noticed a screw falling on my table and the screw to the right of the USB port was missing
    • I also noticed the screw to the left being loose
  7. Punkt MP02 Teardown: étape 7, image 1 de 1
    • Now remove eight screws and the power button
  8. Punkt MP02 Teardown: étape 8, image 1 de 1
    • I unplugged the two antenna cables
    • unplug the battery connector
  9. Punkt MP02 Teardown: étape 9, image 1 de 1
    • now I opened the clips that hold the ribbon cables
  10. Punkt MP02 Teardown: étape 10, image 1 de 3 Punkt MP02 Teardown: étape 10, image 2 de 3 Punkt MP02 Teardown: étape 10, image 3 de 3
    • at this point the device felt loose and I didn't know how to continue - I noticed after beginning to pull on the battery pull tabs that the mainboard separated
  11. Punkt MP02 Teardown: étape 11, image 1 de 1
    • by gently moving the mainboard down (direction of USB port) the mainboard could be separated
    • notice the metal hook that prevents the device from being separated without downwards movement
  12. Punkt MP02 Teardown: étape 12, image 1 de 1
    • remove the middle screw
  13. Punkt MP02 Teardown: étape 13, image 1 de 2 Punkt MP02 Teardown: étape 13, image 2 de 2
    • Now I could remove the screen and main board
Florian
Membre depuis le 08/24/23
237 Réputation
1 tutoriel rédigé
Un commentaire
Thank you for posting this guide. It'll become more valuable as these devices age--I anticipate having to replace the battery sometime in the next two years.
vvaylon_k - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 62
Total : 1,181
