Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre BlackBerry 7290, utilisez notre manuel de réparation.
  1. RIM Blackberry 7290 Teardown, Battery: étape 1, image 1 de 3 RIM Blackberry 7290 Teardown, Battery: étape 1, image 2 de 3 RIM Blackberry 7290 Teardown, Battery: étape 1, image 3 de 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. RIM Blackberry 7290 Teardown: étape 2, image 1 de 3 RIM Blackberry 7290 Teardown: étape 2, image 2 de 3 RIM Blackberry 7290 Teardown: étape 2, image 3 de 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. RIM Blackberry 7290 Teardown, SIM Card: étape 3, image 1 de 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. RIM Blackberry 7290 Teardown: étape 4, image 1 de 2 RIM Blackberry 7290 Teardown: étape 4, image 2 de 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. RIM Blackberry 7290 Teardown, Side Button: étape 5, image 1 de 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. RIM Blackberry 7290 Teardown: étape 6, image 1 de 2 RIM Blackberry 7290 Teardown: étape 6, image 2 de 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. RIM Blackberry 7290 Teardown: étape 7, image 1 de 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. RIM Blackberry 7290 Teardown: étape 8, image 1 de 3 RIM Blackberry 7290 Teardown: étape 8, image 2 de 3 RIM Blackberry 7290 Teardown: étape 8, image 3 de 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. RIM Blackberry 7290 Teardown: étape 9, image 1 de 2 RIM Blackberry 7290 Teardown: étape 9, image 2 de 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. RIM Blackberry 7290 Teardown, Keypad: étape 10, image 1 de 1
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. RIM Blackberry 7290 Teardown: étape 11, image 1 de 1
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. RIM Blackberry 7290 Teardown: étape 12, image 1 de 1
    • Turn the internals over to reveal the LCD display.
  13. RIM Blackberry 7290 Teardown: étape 13, image 1 de 2 RIM Blackberry 7290 Teardown: étape 13, image 2 de 2
    • Peel off the rubber keypad buttons from the face plate.
  14. RIM Blackberry 7290 Teardown, LCD: étape 14, image 1 de 1
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
  15. RIM Blackberry 7290 Teardown: étape 15, image 1 de 2 RIM Blackberry 7290 Teardown: étape 15, image 2 de 2
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
  16. RIM Blackberry 7290 Teardown, Logic Board: étape 16, image 1 de 1
    • On the front side of the internals, locate the the three screws that are highlighted in red.
    • Carefully remove screws from the internals, using a T6 torx screwdriver
    • The screw is .2 inches in length.
  17. RIM Blackberry 7290 Teardown: étape 17, image 1 de 2 RIM Blackberry 7290 Teardown: étape 17, image 2 de 2
    • Separate the logic board mounting plate from the logic board by lifting with minimal force.
  18. RIM Blackberry 7290 Teardown, RIM Blackberry 7290 Teardown: étape 18, image 1 de 2 RIM Blackberry 7290 Teardown, RIM Blackberry 7290 Teardown: étape 18, image 2 de 2
    • These are all the components of the phone.
kenny34
Membre depuis le 10/28/09
75 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 19-6, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 6,439
