Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Revlon Perfect Heat Jumbo 3 Barrel Waver, utilisez notre manuel de réparation.
  1. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: étape 1, image 1 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: étape 1, image 2 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: étape 1, image 3 de 3
    • Make sure your the device is unplugged before starting this teardown.
    • The device used in this tear-down is missing the lever and spring.
    • Remove these items by lifting up on the lever until it pops out of place. The spring should come out easily.
  2. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: étape 2, image 1 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: étape 2, image 2 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: étape 2, image 3 de 3
    • Remove all of the screws on the back of the plastic covering.
  3. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Handle Casing: étape 3, image 1 de 1
    • Remove the plastic handle cover by lifting it straight up.
  4. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: étape 4, image 1 de 2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: étape 4, image 2 de 2
    • Remove the small black screw that is holding the circuit board in place.
  5. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: étape 5, image 1 de 2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: étape 5, image 2 de 2
    • Remove the power cord from the power port of the Waver by holding the port with one hand and pulling on the cord with the other hand.
  6. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: étape 6, image 1 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: étape 6, image 2 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: étape 6, image 3 de 3
    • Remove the two metal cylinders by sliding them down the length of the inner soft cylinders.
    • The internal ceramic cylinders are very soft and tear easily. Be careful not to damage them.
  7. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: étape 7, image 1 de 2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: étape 7, image 2 de 2
    • Remove the plastic cylinder holders by lifting them up and along the length of the cylinder.
  8. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Rear Metal Plate: étape 8, image 1 de 1
    • Similar to step 4, remove the back metal plate by sliding down the length of the intern cylinder.
    • The internal cylinder is very soft and tears easily. Be careful not to damage it.
  9. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: étape 9, image 1 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: étape 9, image 2 de 3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: étape 9, image 3 de 3
    • Gently lift the circuit board and tilt it to the side.
    • Lift the dial straight up from the circuit board. It should come off easily.
  10. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Full Teardown: étape 10, image 1 de 1
    • Here are all of the safely removeavable components of the waver
Kyle Weeks
Membre depuis le 09/26/12
116 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-45, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 815
