Introduction
A look inside the Ring Glass Break Sensor.
Ce dont vous avez besoin
Features:
Glass Break Detector
Real-Time Notifications
Simple Setup and Simple App Connection
Uses three replaceable AA Batteries
Next, separate the top with a iFixit Opening Tool to get access to the electronics inside.
There are number of catches around the outside of the device. These catches popped loose fairly easily with the iFixit Opening Tool.
Once the top is removed, we get our first look at the internal PCB
Close up view of the back side of the battery compartment that also supports the internal PCB
Power from the batteries is passed to the PCB via metal tabs
Tab on the enclosure interfaces to the slide switch on the PCB to cut power when the bottom of the enclosure is rotated to access the batteries
Battery Mating Connectors for the battery compartment metal tabs . The non-forced connectors allow for easy removal of the PCB from the enclosure
Close up view of the backside of the PCB
MEMS Microphone, Vesper VM3011 - World's First Adaptive ZEROPOWER Listening™ Digital Piezoelectric MEMS Microphone
Close up view of the MEMS Microphone
Switch/button operation is not documented
Power Shutoff Switch. When the bottom is rotated to access the batteries - this switch slides as the enclosure bottom is rotated to shutoff battery power to the PCB
Close up view of some of the electrical components on the top side of the PCB. Other than the two large ICs on the topside of the PCB, the other components look to be related to power management and control
Syntiant, NDR101BQQF. Always-on Neural Processor. Used for detecting the breaking glass
Silicon Labs, RZ13M1442. Z-Wave Long Range Radio with ARM MCU
5 commentaires
Neat! Given that it uses a microphone, I wonder if playing the sound of breaking glass over a pair of speakers would accidentally set it off.
Yes it would. That is probably how it is tested.
No, it doesn't. Many people have tried but it's now a well-known fact in the Ring Community that the sensor can't be tested using this method. The agreed method is to carefully break a glass or a bottle in its vicinity which does set the alarm off.
My basement windows are on the ground level, where an intruder could easily kick them in, so I decided to install the Glass Break Sensor there. Just in case, I installed a Ring Z-Wave Range Extender. I brought a couple of empty bottles, slope game a medium-sized pickle jar (also empty), and a large rock from my yard down into the basement because I didn't want to sacrifice any of my actual windows.
Sometimes tossing a keyring full of keys in the air and catching them in your hand is enough to set of a glass break sensor for a test.
