Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Evergreen SGH-A667, utilisez notre manuel de réparation.
  1. Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: étape 1, image 1 de 2 Samsung Evergreen SGH-A667 Teardown, Samsung Evergreen SGH-A667 Teardown: étape 1, image 2 de 2
  2. Samsung Evergreen SGH-A667 Teardown: étape 2, image 1 de 1
    • Begin by prying off the rear battery-access panel.
  3. Samsung Evergreen SGH-A667 Teardown: étape 3, image 1 de 2 Samsung Evergreen SGH-A667 Teardown: étape 3, image 2 de 2
    • Remove battery pack and SIM card.
    • Remove the seven screws marked in red.
  4. Samsung Evergreen SGH-A667 Teardown: étape 4, image 1 de 2 Samsung Evergreen SGH-A667 Teardown: étape 4, image 2 de 2
    • Pry the case away from the body of the phone. Be gentle around the volume control, micro USB, and micro SD ports.
  5. Samsung Evergreen SGH-A667 Teardown: étape 5, image 1 de 2 Samsung Evergreen SGH-A667 Teardown: étape 5, image 2 de 2
    • Camera
    • Keyboard ribbon connector
    • Microphone
    • Remove the two screws marked in red to free the EMI shielding.
  6. Samsung Evergreen SGH-A667 Teardown: étape 6, image 1 de 1
    • The keyboard ribbon strings each of the pieces together, but the keypad flops right out on its own.
  7. Samsung Evergreen SGH-A667 Teardown: étape 7, image 1 de 2 Samsung Evergreen SGH-A667 Teardown: étape 7, image 2 de 2
    • Remove the six screws marked in red; they hold the keyboard to the sliding mechanism.
  8. Samsung Evergreen SGH-A667 Teardown: étape 8, image 1 de 3 Samsung Evergreen SGH-A667 Teardown: étape 8, image 2 de 3 Samsung Evergreen SGH-A667 Teardown: étape 8, image 3 de 3
    • Huzzah the sliding carriage is free—what's that? The funk of forty thousand years? This part of the phone never sees the light of day!
    • Remove the six screws circled in red.
    • Sometimes this screw is hidden by the ribbon cable!
  9. Samsung Evergreen SGH-A667 Teardown: étape 9, image 1 de 3 Samsung Evergreen SGH-A667 Teardown: étape 9, image 2 de 3 Samsung Evergreen SGH-A667 Teardown: étape 9, image 3 de 3
    • More plastic clips means a little more finagling to pry the front case off.
    • The work pays off with a snappy line-up.
  10. Samsung Evergreen SGH-A667 Teardown: étape 10, image 1 de 2 Samsung Evergreen SGH-A667 Teardown: étape 10, image 2 de 2
    • Gently flex the faceplate to loosen the adhesive's hold on the screen.
    • After loosening all edges, begin to peel the LCD from the plastic. When in doubt, stop, look, and listen; just like crossing the street.
  11. Samsung Evergreen SGH-A667 Teardown: étape 11, image 1 de 1
    • The sum of its parts
    • Use these steps in reverse to reassemble—a method tried and true!
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 27
Total : 782
