Ce dont vous avez besoin
Remove SIM card tray at first. It's Samsung Galaxy Note 5 Duos, so there are two slots.
Since Samsung applied the design that the USB board come with soft keys together, DIY replace USB board and LCD screen alone become much more difficult.
Be careful with the soft sensor keys on the bottom especially the flex.
In fact, the replacement of Samsung Galaxy Note 5 LCD screen, USB board or home button nearly the same with that teardown.
24 commentaires
Can the s pen be opened too? I wanna know because my s pen clicking mechanism gets stuck and doesn't click.
Yes it separates at the seam where the darker section with the Samsung text meets the light gray part. Here is a decent youtube video some guy made: https://youtu.be/ixNXUh2fnZo I would recommend trying plastic tools to open instead of a razor blade, also graphite is quite messy so I would probably use a small dab of light silicone grease. I buy it at the hardware store in the plumbing section (used for faucet seals). It's a good lightweight grease for rubber & plastic parts and anything sensitive to petroleum base grease. Good luck!
So did you find out where is the memory stored? My Note 5 dropped in water and circuit on the motherboard is fried. Is there a way i can still recover my data???
