Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. Samsung SCH-U340 Teardown, Samsung SCH-U340 Teardown: étape 1, image 1 de 1
    • The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
  2. Samsung SCH-U340 Teardown: étape 2, image 1 de 1
    • After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
  3. Samsung SCH-U340 Teardown: étape 3, image 1 de 1
    • The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
  4. Samsung SCH-U340 Teardown: étape 4, image 1 de 1
    • Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
  5. Samsung SCH-U340 Teardown: étape 5, image 1 de 1
    • Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
Anish Sambamurthy
Membre depuis le 02/11/10
29 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 995
