Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung SGH-X450, utilisez notre manuel de réparation.
  1. Take out the battery and SIM Card.
    • Take out the battery and SIM Card.
  2. Remove these screws.
    • Remove these screws.
  3. If the screws are removed, you can take the case of with your fingers or a small flathead screwdriver
    • If the screws are removed, you can take the case of with your fingers or a small flathead screwdriver
  4. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  5. Now you see the PCB
    • Now you see the PCB
    • Agere TR09WQTEF2B Processor
    • Agere PSC2106 Power Management IC
    • Battery contacts and power supply connector
    • SIM Card Slot
    • Back-Up battery
    • Antenna connector
    • 2,5mm Headphone Jack
  6. LCD Dispaly cable, you can release this connector with a small flathead screwdriver
    • LCD Dispaly cable, you can release this connector with a small flathead screwdriver
    • Be careful here, You can break the flatcable!
  7. To take the LCD display out of the case, click the upper case open with a small flathead screwdriver or case opener. Under the two pads under the LCD Display are 2 screws. Be also careful here, go not to far with the screwdriver so you can not damage the LCD display.
    • To take the LCD display out of the case, click the upper case open with a small flathead screwdriver or case opener. Under the two pads under the LCD Display are 2 screws.
    • Be also careful here, go not to far with the screwdriver so you can not damage the LCD display.
  8. Now you see this.
    • Now you see this.
    • If you want to remove the LCD display, lift the PCB of the LCD display up with a small flathead screwdriver.
  9. Finished!
    • Finished!
Bryan
Membre depuis le 27/10/2012
690 Réputation
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,415
