Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sidekick II, utilisez notre manuel de réparation.
  1. Sidekick II Teardown, Outer Casing: étape 1, image 1 de 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Teardown: étape 2, image 1 de 2 Sidekick II Teardown: étape 2, image 2 de 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Teardown: étape 3, image 1 de 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Teardown: étape 4, image 1 de 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Teardown: étape 5, image 1 de 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Teardown, Sidekick II Teardown: étape 6, image 1 de 2 Sidekick II Teardown, Sidekick II Teardown: étape 6, image 2 de 2
    • Remove screen from casing.
  7. Sidekick II Teardown: étape 7, image 1 de 2 Sidekick II Teardown: étape 7, image 2 de 2
    • Remove 4 screws from back of screen using Torx 6 Screwdriver.
    • Pry screen out of casing using fingers.
  8. Sidekick II Teardown: étape 8, image 1 de 3 Sidekick II Teardown: étape 8, image 2 de 3 Sidekick II Teardown: étape 8, image 3 de 3
    • Remove 4 screws from front of screen with Phillip screwdrivers.
    • Peel off the metal covering on the back of the screen.
    • Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
  9. Sidekick II Teardown: étape 9, image 1 de 1
    • Remove the protective cover in front of the screen.
    • Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
  10. Sidekick II Teardown: étape 10, image 1 de 2 Sidekick II Teardown: étape 10, image 2 de 2
    • Take the screws out using the Torx 6 screwdriver.
    • Then lift the thumb wheel and housing off of the front panel.
  11. Sidekick II Teardown: étape 11, image 1 de 2 Sidekick II Teardown: étape 11, image 2 de 2
    • Remove 2 black "rivets" from back of casing with the plastic opening tool.
    • Press keyboard out of front of casing using thumbs. Don't press too hard as you may break the board.
  12. Sidekick II Teardown: étape 12, image 1 de 2 Sidekick II Teardown: étape 12, image 2 de 2
    • Remove the 5 black screws with a Phillips head screwdriver.
    • Lift the bottom of the control board from housing, and separate the two.
  13. Sidekick II Teardown: étape 13, image 1 de 1
    • Carefully remove battery and back plate.
    • Do not use metal tools, you may damage the control board. Use only your fingers.
  14. Sidekick II Teardown: étape 14, image 1 de 1
    • Here are all of the pieces that you have disassembled
michael albaum
Membre depuis le 01/20/10
87 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-19, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 membres
11 tutoriels rédigés
Un commentaire
nice job from a former geek
Jared Boies - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 52
Total : 7,278
