Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sky TV Remote, utilisez notre manuel de réparation.
  1. Sky TV Remote Teardown, Sky TV Remote Teardown: étape 1, image 1 de 3 Sky TV Remote Teardown, Sky TV Remote Teardown: étape 1, image 2 de 3 Sky TV Remote Teardown, Sky TV Remote Teardown: étape 1, image 3 de 3
    • This is it. Well, this is it in a functional state.
    • Remove the batteries before starting!
  2. Sky TV Remote Teardown: étape 2, image 1 de 3 Sky TV Remote Teardown: étape 2, image 2 de 3 Sky TV Remote Teardown: étape 2, image 3 de 3
    • Use a Philips head screwdriver to remove this screw
    • Use a spudger to unlock all the tabs around the sides, start at the bottom
    • Work your way all the way around the remote, this is flippin' tricky.
    • Brute force is compulsory.
  3. Sky TV Remote Teardown: étape 3, image 1 de 3 Sky TV Remote Teardown: étape 3, image 2 de 3 Sky TV Remote Teardown: étape 3, image 3 de 3
    • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
    • Ta-daa!
QEIIRepair
66 Réputation
1 tutoriel rédigé
3 commentaires
On early models theres a second screw under the black infa red filter. If it doesnt come apart as above, ther black filter is held on by two tabs. On the battery compartment side, the black plastic nearest the battery, wedge a small screwdriver between the body and the pastic and the filter should slide away revealing a second screw!
tim - Réponse
How do I clean? Buttons not making electrical connection. New remots don't recognize my TV.
Ronald Welemin - Réponse
Also, is there a product that I can put on the connection buttons to improve contact?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 129
30 derniers jours : 151
Total : 16,960
