Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sonos Play 5, utilisez notre manuel de réparation.
  1. Sonos Play 5 Teardown, Sonos Play 5 Teardown: étape 1, image 1 de 1
    • Pull the front bezel forward to remove. It's only secured by velcro
  2. Sonos Play 5 Teardown: étape 2, image 1 de 3 Sonos Play 5 Teardown: étape 2, image 2 de 3 Sonos Play 5 Teardown: étape 2, image 3 de 3
    • Gently peel the rubber base away from the edges to remove 6 phillips head screw.
    • The base plate will lift straight up to reveal 3 metal stanchions. I believe these are the wireless antennas.
  3. Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: étape 3, image 1 de 1
    • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
    • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
    • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Tim U
Membre depuis le 06/21/13
101 Réputation
1 tutoriel rédigé
Un commentaire
This teardown is stale! Please continue. :) Thanks.
William Small - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 32
30 derniers jours : 107
Total : 15,841
