Outils recommandés dans ce démontage
Introduction
I will teach you how to deconstruct a DVD-ROM unit into it's base assembly and then show what many people use to build a burning laser.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Toshiba Samsung Storage DVD Writer(TS-H653), utilisez notre manuel de réparation.
Remove outside screws using a screwdriver that fits a M3x6 screw
  • Remove outside screws using a screwdriver that fits a M3x6 screw
Ajouter un commentaire
Gently pry up the top casing with the model sticker facing down. Apply a wiggling motion side to side if necessary
  • Gently pry up the top casing with the model sticker facing down. Apply a wiggling motion side to side if necessary
  • Remove all detachable ribbons by wiggling back and forth on a horizontal axis
  • Check for any remaining screws around the edge of the board, if there are none apparent double check the ribbons and the slide the board back until it slides free
  • To remove the tan plastic, ensure all of the screws have been removed on the metal tabs shown in red
  • apply a teetering pull apply more lift to one side that the other
  • My part was already broken! It might be slightly different for you
  • Now most inside components should be loose and removable
  • This is a picture of the removal process of the laser diode component(it is still encased in the moving and refraction related parts)
  • Ensure to hand this with care!
  • Remove the three screws surrounding the second component
  • Remove and check for removal of all ribbons on this component(note the orange is labeled "lead free")
  • Undo the screws on the side of the stepper component with A DIFFERENT SCREWDRIVER TO AVOID STRIPPING
  • The screwdriver will be smaller than the M3x6 fit
  • Gently extract after screw removal
  • flip the leftovers over and slide the peice of black plastic far forward to remove the screws holding the metal in place
  • Slide the disk tray back if you can not remove it completely and proceed to unscrew the final and 3rd screw.
  • You will need a different screwdriver! Use the wiggle test to find the right fit! They will strip extremely easily!
  • Gently remove any clips to allow the only holder to be the rubber wheels to be holding it(circled in red)
  • Gently apply pressure to pull away from the main casing
  • Un-clip the clips seen in photo 2
  • To remove the pole that was in the picture before it was removed, push down on the spring with a screw at one end removed the tilt one end up and remove
  • To remove toothed gears push the clip inside the spire in the middle of the gear, and maintaining pressure on the clip pull away the gear
  • Apply the same technique as in picture 2 but with the clip in picture 3
  • Your pretty much done with this deconstruction
  • If you wish to remove the laser diode be careful! Picture #3 is evidence of my failure to this
Owen Preece
Membre depuis le 10/04/2018
633 Réputation
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 243
