Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
I have a PlayStation 1, and i have decided to make a new teardown of it.
I'm spanish, so my english is a bit poor, and sorry for the mistakes made in this teardown.
Without further delay, we start.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre PlayStation, utilisez notre manuel de réparation.
  1. Here's the PS1. Turn the PS1 over and remove the six screws.
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
  2. Remove the top cover. It's very easy.
    • Remove the top cover. It's very easy.
  3. Disconnect both CD-ROM connectors.
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
  4. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Detach both cables. They go to the power supply and to the memory cards and controller connectors.
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Remove the four screws and the metal cover.
    • Remove the four screws and the metal cover.
  7. Now you have the motherboard!
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Once the screws are removed, remove the power supply.
    • Once the screws are removed, remove the power supply.
  9. Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Now, you have all your PlayStation 1 parts!
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
Membre depuis le 06/05/2010
170 Réputation
1 tutoriel rédigé
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 28
30 derniers jours : 128
Total : 23,139
