Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre VicTsing MM057 2.4G Wireless Mouse, utilisez notre manuel de réparation.
  1. VicTsing MM057 2.4G Wireless Mouse Teardown, VicTsing MM057 2.4G Wireless Mouse Teardown: étape 1, image 1 de 1
    • The VicTsing MM057 2.4G Wireless Mouse.
  2. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 2, image 1 de 1
    • Filp over and remove battery cover and USB dongle.
    • Mouse
    • USB dongle
    • Battery cover
  3. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 3, image 1 de 1
    • Remove three screws. Two screws are located under the adhesive pads closer to the front of the mouse. The third screw is under the battery cover.
    • Screw locations
  4. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 4, image 1 de 1
    • Gently pull apart the enclose. Be wary of the board-to-board connector cables.
    • Board-to-board receptacle
  5. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 5, image 1 de 1
    • Disconnect the board-to-board cables by squeezing the sides of the receptacles on base.
    • Top
    • Base
  6. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 6, image 1 de 1
    • Separate battery connection wires from the base chassis and remove the base circuit board and optical lens.
    • Base circuit board
    • Optical lens
    • Base chassis
  7. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 7, image 1 de 1
    • Remove the scroll wheel.
    • Scroll wheel
    • From top to bottom: right click, wheel click, wheel rotary encoder, and left click actuators
    • Crystal oscillator (12 MHz)
    • From left to right: optical receiver and red LED
  8. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 8, image 1 de 1
    • Underside of base circuit board.
    • Microcontroller (epoxy coated)
    • Bluetooth antenna
    • Optical receiver (bottom side)
  9. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 9, image 1 de 1
    • Remove screw from center of top circuit board.
    • Screw location
  10. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 10, image 1 de 1
    • Separate top circuit board from the top chassis.
    • Top chassis
    • Top circuit board
  11. VicTsing MM057 2.4G Wireless Mouse Teardown: étape 11, image 1 de 1
    • Mode selector button
    • Side buttons
    • LED status indicator
Neil
Membre depuis le 03/06/18
213 Réputation
1 tutoriel rédigé
6 commentaires
This is a nice guide keep up the good work!!!!
Damon Diller - Réponse
Hello, thanks for the tutorial. My mouse is the same as this model.
From time to time it simply disconnects by itself and after a few seconds, it reconnects. I’ve changed batteries already.
This one problem is very annoying, but it works perfectly and I’d really like to keep using it - so I wish I could fix it to continue using it.
Do you guys know anything I could do to solve this?
Victor Pietro Moreno - Réponse
Mine disconnects after a few minutes of being idle. I just click the left mouse button once to “wake” it. Moving the mouse around will not wake it. I think this is by design to prevent the radio to the USB dongle from needlessly draining the battery. If this is different from what you are experiencing, then the other thing to do would be to consider whether you have other wireless devices that could be causing interference.
Erik Van Eaton -
Thank you for this guide. I just used it to inspect the wheel. Mine was causing “up-and-down” scrolling behavior on the screen despite rolling the wheel only down. After using this guide to disassemble and clean the mouse, it is working perfectly again.
Erik Van Eaton - Réponse
I have the same problem with the scroll wheel. I know how to open the mouse, however, what type of cleaning did you do in order to get the wheel to work properly again?
Thank you
Zalman Rosenthal -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 4,226
