Introduction
Guides you in taking apart the Slimlighter Super-LED for maintenance or just pure curiousity :)
Ce dont vous avez besoin
This is Whelen's second generation Slimlighter. Whilst the first generation had multiple 5mm LED's, this generation Slimlighter has 'only' 12 TIR6 style LED's.
Enough chatter, let's take it apart :)
Optionally one can first take of the suctioncup brackets. They are held in place by two Philips screws.
Next you can take off the retaining brackets. They are held back by a little notch that has to be lifted with a spudger. Repeat this step for the other side.
Once the notch is lifted pull the bracket away from the light as shown.
Once the brackets are released the light can easily be dissasembled. Begin by lifting the diffuser lens up as shown.
One can also have clear lenses here, the procedure is the same.
Note that the lens has a similar notch on the other side, underneath the Whelen logo. Carefully pull the lens out from underneath, don't force anything or it will break.
If desired, take out the six Philips screws to remove the LED circuit board from the bracket.
Note that the rear circuit board is held back by the same screws.
The LED board can easily be replaced by any other TIR6 board, any color (as far as I could check!)
Note that there is cooling paste between the LED board and the bracket. Make sure you replace it.
