Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. Xiaomi Mi Power Bank  10400mAh Teardown, Xiaomi Mi Power Bank  10400mAh Teardown: étape 1, image 1 de 1
    • This is the model
  2. Xiaomi Mi Power Bank  10400mAh Teardown: étape 2, image 1 de 3 Xiaomi Mi Power Bank  10400mAh Teardown: étape 2, image 2 de 3 Xiaomi Mi Power Bank  10400mAh Teardown: étape 2, image 3 de 3
    • Remove it with a knife. Be really careful not to cut yourself
    • The top is attached with double sided tape.
  3. Xiaomi Mi Power Bank  10400mAh Teardown: étape 3, image 1 de 1
    • Remove 4 screws, and push the battery and circuit board out.
    • You need to resolder the battery to the PCB.
    • To keep the battery tight I used a piece of double sided foam tape on on of the edge cells
Martin Hampton
Membre depuis le 02/13/16
1 308 Réputation
7 tutoriels rédigés
2 commentaires
Umm there’s missing steps - the bottom cover also needs removed? How do you push the battery out? Both sides are screwed in please help or finish t his guide thanks
emanoyhl - Réponse
Hi emanoyhl, this guide is a teardown and it looks like it is still in progress, so it's not totally complete yet. I did a search and found a guide for a similar device but for the LED however it does show a little more of the internals. Check out the Jerking LED fix in 10000mAh Mi Power Bank 2S, it's not exactly the same device but it seems to have similar construction and you might be able to reach the battery the same way? I hope this helps!
Sarah Westberg -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 65
Total : 4,720
