Outils recommandés dans ce démontage
Introduction
This manual will guide you through the steps involved in successfully removing the components of your Zune. This includes the hard drive, battery, screen, logic board, etc.
Use a metal spudger or Zune opening tool to remove the small silver plastic cap located on top of the device.
Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound. It is now disengaged from the hard drive.
Now, gently pull the orange hard drive cable to remove it from the hard drive cable.
Lift the hard drive out of the device.
Remove the battery from the device with the cables still connected.
Carefully lift up the logic board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
Remove the logic board from the Zune, leaving the black wire connected.
