Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Acer Aspire One 725, utilisez notre manuel de réparation.
  1. acer aspire one 725 Teardown, This is an acer aspire one: étape 1, image 1 de 3 acer aspire one 725 Teardown, This is an acer aspire one: étape 1, image 2 de 3 acer aspire one 725 Teardown, This is an acer aspire one: étape 1, image 3 de 3
    • prepare you're self for a lot of screws
  2. acer aspire one 725 Teardown, Remove the battery: étape 2, image 1 de 3 acer aspire one 725 Teardown, Remove the battery: étape 2, image 2 de 3 acer aspire one 725 Teardown, Remove the battery: étape 2, image 3 de 3
    • on the top right corner and slide it to the right
    • It release very easily
  3. acer aspire one 725 Teardown, Getting inside the laptop: étape 3, image 1 de 3 acer aspire one 725 Teardown, Getting inside the laptop: étape 3, image 2 de 3 acer aspire one 725 Teardown, Getting inside the laptop: étape 3, image 3 de 3
    • There's a screw natural reaction unscrew it
    • Slide the cover right off
  4. acer aspire one 725 Teardown, Removing the ram: étape 4, image 1 de 3 acer aspire one 725 Teardown, Removing the ram: étape 4, image 2 de 3 acer aspire one 725 Teardown, Removing the ram: étape 4, image 3 de 3
    • Simply push these pins out and it'll come out
    • It's kinda fun to taking it out and pushing it back in
  5. acer aspire one 725 Teardown, Removing the hard drive: étape 5, image 1 de 3 acer aspire one 725 Teardown, Removing the hard drive: étape 5, image 2 de 3 acer aspire one 725 Teardown, Removing the hard drive: étape 5, image 3 de 3
    • More screws unscrew them
    • It might be hard to removing the hard drive so use the screwdriver to push it out
  6. acer aspire one 725 Teardown, Still removing the hard-drive: étape 6, image 1 de 3 acer aspire one 725 Teardown, Still removing the hard-drive: étape 6, image 2 de 3 acer aspire one 725 Teardown, Still removing the hard-drive: étape 6, image 3 de 3
    • This is what it should look like
    • You can also change the hard-drive if you want by unscrewing the metal piece
  7. acer aspire one 725 Teardown, Just a look: étape 7, image 1 de 1
    • to see how it looks like
  8. acer aspire one 725 Teardown, Before removing the keyboard: étape 8, image 1 de 2 acer aspire one 725 Teardown, Before removing the keyboard: étape 8, image 2 de 2
    • Please remove the black and blue strip
    • These are connected to the keyboard
    • Also unscrew all the screws keeping the panel down
  9. acer aspire one 725 Teardown, Removing the keyboard: étape 9, image 1 de 2 acer aspire one 725 Teardown, Removing the keyboard: étape 9, image 2 de 2
    • pry it open by where the battery was
    • These show the mother board
    • There are multiple screws, black screws and sliver screws
    • I labeled black screws with red. I labeled the sliver screws with yellow.
  10. acer aspire one 725 Teardown, The touch pad: étape 10, image 1 de 3 acer aspire one 725 Teardown, The touch pad: étape 10, image 2 de 3 acer aspire one 725 Teardown, The touch pad: étape 10, image 3 de 3
    • There is a purple strip and unhook it
    • Take off the panel that the blue and purple strip its connected to
  11. acer aspire one 725 Teardown, The key board separated: étape 11, image 1 de 2 acer aspire one 725 Teardown, The key board separated: étape 11, image 2 de 2
    • A look of the key board
  12. acer aspire one 725 Teardown, So far we gone: étape 12, image 1 de 3 acer aspire one 725 Teardown, So far we gone: étape 12, image 2 de 3 acer aspire one 725 Teardown, So far we gone: étape 12, image 3 de 3
    • I know that we didn't take apart the mother board but this is all that
    • I hope that you find this useful
Poua Yang
Membre depuis le 11/10/16
171 Réputation
1 tutoriel rédigé
2 commentaires
thanks !!!! a lot
alej689 - Réponse
Great guide, Thanks.
Do you know if there is a lithium battery (coin shape) ? or a jumper for BIOS password resetting ?
Nico Land - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 23
Total : 3,721
