Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Vidéo d'introduction
Introduction
Laminating process of iPhone X OLED screen is much complicated than LCD screen. Fit OLED with TP for the first time, then fit OLED with 3D Touch for the second time. The whole process counts more than 15 procedures.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iPhone X, utilisez notre manuel de réparation.
  1. Test the iPhone X screen before tearing down. Run function test - Display; Touch; 3D Touch and Swipe-up. All going well.
    • Test the iPhone X screen before tearing down. Run function test - Display; Touch; 3D Touch and Swipe-up. All going well.
  2. Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner. Cut a plastic horn of the bezel with the blade if necessary and then remove bezel with Pry Piece and Glue Cleaner carefully.
    • Place the OLED Screen Assembly on the Heat Platform. Remove bezel slowly with Pry Piece and Glue Cleaner. Cut a plastic horn of the bezel with the blade if necessary and then remove bezel with Pry Piece and Glue Cleaner carefully.
    • Be careful with flex cables when removing bezel in the flex cable area.
  3. Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with cutting wire. We are working with one OLED flexible screen, so be careful with your handwork.
    • Place the OLED Screen Assembly on the Heat Platform. Separate the glass lens from OLED with cutting wire. We are working with one OLED flexible screen, so be careful with your handwork.
  4. Glue removing for iPhone X screen can be applied with hand tearing
    • Glue removing for iPhone X screen can be applied with hand tearing
  5. Different from Samsung smartphones, iPhone X has its 3D Touch module adhered behind OLED backplane.
    • Different from Samsung smartphones, iPhone X has its 3D Touch module adhered behind OLED backplane.
    • Different from all iPhone previous versions, the 3D Touch module of iPhone X is bonded to the OLED panel.
    • To fully analyze its structure, we took a disruptive disassembly of the 3D Touch module.
    • The 3D touch and TP flex bonding are also separated after the disassembly.
  6. Here is the structure of iPhone X OLED screen.
    • Here is the structure of iPhone X OLED screen.
Phryne
Membre depuis le 17/11/2019
10 421 Réputation
80 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 136
Total : 2,202
