Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Countertop Ice Maker, utilisez notre manuel de réparation.
  1. ikich Countertop Ice Maker Teardown, safety first: étape 1, image 1 de 1
    • Remember that ice makers contain toxic refrigerant. Hand and eye protection are recommended
    • A medium phillips-head screwdriver is also required
  2. ikich Countertop Ice Maker Teardown, unplug and drain: étape 2, image 1 de 2 ikich Countertop Ice Maker Teardown, unplug and drain: étape 2, image 2 de 2
    • unplug your countertop ice maker
    • place over the sink and pull out the rubber stopper from the bottom
    • wait for all fluid to drain
  3. ikich Countertop Ice Maker Teardown, remove back housing: étape 3, image 1 de 1
    • Once drained, place ice maker on its side. Remove the highlighted screws that hold the back plastic cover in place.
    • Then remove the black plastic cover.
  4. ikich Countertop Ice Maker Teardown, remove top housing: étape 4, image 1 de 1
    • remove the screws holding the top cover in place.
    • Don't forget the other side!
  5. ikich Countertop Ice Maker Teardown, remove tray motor and water intake: étape 5, image 1 de 1
    • remove two screws holding the tray motor in place. Then pull the tray motor straight out. It may require a bit of force if rust is sticking it onto the tray
    • remove the water intake hose by pulling it straight down
  6. ikich Countertop Ice Maker Teardown, remove side panel wires: étape 6, image 1 de 2 ikich Countertop Ice Maker Teardown, remove side panel wires: étape 6, image 2 de 2
    • uncover the electronics by unclipping the specified points
    • unplug the wire connecting to the right side panel
  7. ikich Countertop Ice Maker Teardown, remove side panels: étape 7, image 1 de 2 ikich Countertop Ice Maker Teardown, remove side panels: étape 7, image 2 de 2
    • remove the screws holding the side panels in-place
    • unscrew the refrigerant pipes from the side panel
    • carefully remove both side panels
  8. ikich Countertop Ice Maker Teardown, remove ice tray: étape 8, image 1 de 2 ikich Countertop Ice Maker Teardown, remove ice tray: étape 8, image 2 de 2
    • at this point, the ice tray should be freed up for removal (and cleaning)
macro
Membre depuis le 09/02/23
157 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
I am looking for an ikich ice maker ice basket insert
Susan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 96
Total : 1,052
