Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre toshiba satellite pro T130-138, utilisez notre manuel de réparation.
  1. toshiba satellite pro T130-138 Teardown, turning off: étape 1, image 1 de 1
    • turn off your computer for safety reasons
  2. toshiba satellite pro T130-138 Teardown, unscrewing case and getting RAM boards out: étape 2, image 1 de 3 toshiba satellite pro T130-138 Teardown, unscrewing case and getting RAM boards out: étape 2, image 2 de 3 toshiba satellite pro T130-138 Teardown, unscrewing case and getting RAM boards out: étape 2, image 3 de 3
    • flip the computer over and remove the 12 philips 0 screws this will make the keyboard and trackpad part free
    • then unscrew the two philips 0 screws guarding the 2 RAM boards
  3. toshiba satellite pro T130-138 Teardown, getting RAM boards out: étape 3, image 1 de 2 toshiba satellite pro T130-138 Teardown, getting RAM boards out: étape 3, image 2 de 2
    • you can remove the 2 RAM boards by lifting them up
    • here we have two beautiful RAM boards
  4. toshiba satellite pro T130-138 Teardown, getting hard disk case out: étape 4, image 1 de 3 toshiba satellite pro T130-138 Teardown, getting hard disk case out: étape 4, image 2 de 3 toshiba satellite pro T130-138 Teardown, getting hard disk case out: étape 4, image 3 de 3
    • by unscrewing these 2 star screws size 6 we can lift the hard disk plate.
    • the hard disk is secured by two philips 0 screws
  5. toshiba satellite pro T130-138 Teardown, getting hard disk out: étape 5, image 1 de 3 toshiba satellite pro T130-138 Teardown, getting hard disk out: étape 5, image 2 de 3 toshiba satellite pro T130-138 Teardown, getting hard disk out: étape 5, image 3 de 3
    • unscrew the hard disk screws
    • and use the spudger to slide the hard disk out
    • pull it up and put it aside
  6. toshiba satellite pro T130-138 Teardown, getting battery out: étape 6, image 1 de 3 toshiba satellite pro T130-138 Teardown, getting battery out: étape 6, image 2 de 3 toshiba satellite pro T130-138 Teardown, getting battery out: étape 6, image 3 de 3
    • slide the two plastic pieces holding the battery
    • and pull it out
    • you will have to take all these silver philips 0 screws
    • but for the next step remove the ones I am pointing
  7. toshiba satellite pro T130-138 Teardown, getting the keyboard bezel out: étape 7, image 1 de 1
    • use a spudger to remove the bezel
  8. toshiba satellite pro T130-138 Teardown, disconnecting keyboard: étape 8, image 1 de 2 toshiba satellite pro T130-138 Teardown, disconnecting keyboard: étape 8, image 2 de 2
    • remove the 2 philips 0 screws and get the keyboard out with a spudger
    • lift the black plastic and pull the cable out
  9. toshiba satellite pro T130-138 Teardown, disconnecting trackpad, on off button and lights: étape 9, image 1 de 3 toshiba satellite pro T130-138 Teardown, disconnecting trackpad, on off button and lights: étape 9, image 2 de 3 toshiba satellite pro T130-138 Teardown, disconnecting trackpad, on off button and lights: étape 9, image 3 de 3
    • follow the same process to disconnect the trackpad, button and lights.
    • you will end up with something like this
  10. toshiba satellite pro T130-138 Teardown, taking top off: étape 10, image 1 de 3 toshiba satellite pro T130-138 Teardown, taking top off: étape 10, image 2 de 3 toshiba satellite pro T130-138 Teardown, taking top off: étape 10, image 3 de 3
    • you have to take this screw located on the RAM boards connector
    • use a spudger to lift the top off, go all around the laptop and you'll get it off
    • It looks really beautiful!
  11. toshiba satellite pro T130-138 Teardown, the trackpad button and lights: étape 11, image 1 de 1
    • this is not a step I am not going deeper into this so I don't break anything you can go if you want.
    • anything that you do that is not shown in the teardown is at your own risk
  12. toshiba satellite pro T130-138 Teardown, inside: étape 12, image 1 de 1
    • the inside contains
    • two speakers
    • one cooler
    • ports
    • screen connector
    • and a giant interesting motherboard
    • oh and don't forget about the memory card reader
  13. toshiba satellite pro T130-138 Teardown, disconnecting the rest: étape 13, image 1 de 3 toshiba satellite pro T130-138 Teardown, disconnecting the rest: étape 13, image 2 de 3 toshiba satellite pro T130-138 Teardown, disconnecting the rest: étape 13, image 3 de 3
    • here we disconnect the battery slot
    • and we get the card reader connector out
    • such as the screen
  14. toshiba satellite pro T130-138 Teardown, disconnecting the rest: étape 14, image 1 de 2 toshiba satellite pro T130-138 Teardown, disconnecting the rest: étape 14, image 2 de 2
    • remove the rest of the cables
    • some of the cables are glued to the mother board don't remove them
    • remove the mother board screws
    • the screen connector is secured by 2 philips 0 screws
  15. toshiba satellite pro T130-138 Teardown, the end: étape 15, image 1 de 1
    • if you did what I did you will end up like this
    • I don't want to go deeper because I don't want to take the risk of breaking or damaging the computer
    • if you go deeper it's at your own risk
    • I will give it an 8/10
    • after removing the screws everything is easy to remove
    • the top, bezels and keyboard come easy off
    • some of the cables and components are fragile with makes it harder to remove
    • the track pad is covered with a sticky plastic with makes it harder to tear down
    • any components that are not well connected can make the computer not function well.
    • the opening tools are there if you want to disconnect some cables that are hard to disconnect
storm builder
Membre depuis le 12/02/17
417 Réputation
1 tutoriel rédigé
4 commentaires
you should take the battery out first, you might shock yourself
Luke - Réponse
So you took the HDD out before the battery… but you turned off the computer for safety reasons.
Isaac Sastre - Réponse
for everyone that was thinking I started the teardown with out removing the battery I took the battery out before starting then i showed how to remove it later but it was not in all the time
storm builder - Réponse
Thanks! Were is the other screen connector flex end plugged in?
jaroschour@gmail.com - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 1,547
