Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre turbidity, utilisez notre manuel de réparation.
first thing  u want to do is take out the two screws on each side of the meter and also take out  all the screws on the bottom  you will need a philips head  screw driver
  • first thing u want to do is take out the two screws on each side of the meter and also take out all the screws on the bottom you will need a philips head screw driver
Ajouter un commentaire
Now unscrew the 4 screws on the face plate  and  you will be able to lift the cover  off  the meter  but be carful as there are a few plugs and screws  left  for you to remove
  • Now unscrew the 4 screws on the face plate and you will be able to lift the cover off the meter but be carful as there are a few plugs and screws left for you to remove
  • Unplug the three prong plug and unscrew and pull out all the wires off the terminal block now you are able to take the cover completely off> the terminal block is basically a neat way of distributing power
  • NOTE: mark where each wire goes on the terminal block for easy re installation
  • Unscrew all the nuts shown using an adjustable wrench to remove circuit board
  • tilt the bulb so screw access is available as shown then slide bulb canister off telescopic shaft
  • tools used : philips head screwdriver flat head screwdriver adjustable wrench
maxwell
Membre depuis le 19/04/2018
133 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 70
