Ce dont vous avez besoin
first thing u want to do is take out the two screws on each side of the meter and also take out all the screws on the bottom you will need a philips head screw driver
Unplug the three prong plug and unscrew and pull out all the wires off the terminal block now you are able to take the cover completely off> the terminal block is basically a neat way of distributing power
NOTE: mark where each wire goes on the terminal block for easy re installation
